FS: HKS Hipermax Max IV SP - lowest price must see
HKS Hipermax Max IV SP sport – 80250-AN005
HKS is offering a few kits on special to introduce them to the US market, no one has them available and this is a one time introductory price. Act FAST!
Sport models are more aggressive and designed for street/strip and aggressive street use, fits people with sticky tires
These are not the Max IV GT that everyone else is selling!! Don't be confused.
Overview:
Fits 03-07 350Z/G35 with VQ35 –
Front spring rate 14kgf/mm – 39mm lowering
Rear spring rate 16kgf/mm – 54mm lowering
Rear is separate spring and shock set up like OEM type with adjustable sleeve
Pics are for example only and are not 350Z kits
Additional info:
Single Tube Damper Design
Mono tube dampers allow for more accurate and stable control and adjustment of dampening. Lower ride height and centre of gravity gives a more stable ride.
Dust Boot
Protect the shaft from the flying stones.
PNE Coating
Using this special surface coating provides 5 times better durability over standard galvanizing. This prevents build-up around the threads of the adjustment areas allowing for easier height adjustment.
M Shaft (Φ46 normal type)
With the new design of cylinder shaft since the HIPERMAX M-1, MAX IV increased the cylinder shaft size to have a firm damping even at a little stroke range by optimizing the oil pressure characteristic. We mainly adopted this to the rear damper that can have a better driving experience.
Pillow Ball Upper Mount
For more accurate and sharp steering.
New Design Needle
Newly designed needle has been used to revise the very low speed and middle and high speed dampening which is key to a comfort ride.
Reduction of Unsprung Weight
In order to reduce unsprung weight, bracket, ride height adjusters and lock nuts are made from aluminium. (Not for all vehicles)
30 Step Damping Force Adjustment
30 levels of dampening adjustment allow fine tune adjustment for street, circuit winding roads, highway, or the weight of the vehicle.
If you want more detail information about the kit from HKS Japan
http://www.hks-power.co.jp/en/produc...ermax/db/15545
Purchasing Details
ETA on this kits are end of August 2014 and only a few kits are being allowed in to America, everyone else is getting the GT which are super soft spring rates.
Price - PM us for your special, list price is $2300 (not your price)
Need a non refundable deposit $100 to payments@gruppe-s.com
Secure your HKS Hipermax coilover today
Overview:
Additional info:
Dust Boot
PNE Coating
New Design Needle
Purchasing Details
08-06-2021 06:19 AM
04-04-2016 07:52 AM
