FS: In stock-spc adjustable front upper control arms - nissan 370z/g37 & g35 sedan
Old 07-22-2015, 06:15 AM
EnjukuRacing
Vendor - Former Vendor
EnjukuRacing's Avatar
Default In stock-spc adjustable front upper control arms - nissan 370z/g37 & g35 sedan
IN STOCK! -
SPC ADJUSTABLE FRONT UPPER CONTROL ARMS - NISSAN 370Z/G37 & G35 SEDAN
Models: Nissan 370Z, Infiniti G37 (Excludes AWD), Infiniti G35 (07-08 Sedan)
Front Camber Adjustability: +/-2.5 Degrees
Front Caster Adjustability: +/-1.0 Degrees
Installation Time: 30-60 minutes per side
These front upper control arms will give you -1 degree to +1.0 degree caster change and up to -2.5 degrees to +2.5 degrees camber change. Simply replace the OE front upper control arms and dial in your suspension angles with our patented sliding ball joint and caster plate. Whether you want to tune your suspension for the ultimate in handling performance, minimize tire wear or easily move back and forth between the two settings, these are the arms to get the job done.
EnjukuRacing is offline
sales@czp
Suspension
54
01-17-2018 09:24 PM
CJs_Z33
09-18-2015 12:06 PM
Quick Reply: FS: In stock-spc adjustable front upper control arms - nissan 370z/g37 & g35 sedan
