From the street to the Track-Suspension Overload-SPL–STANCE-Voodoo13-KW and More
Old 07-31-2015, 09:42 AM
MA-Motorsports
Vendor - Former Vendor
MA-Motorsports's Avatar
Default From the street to the Track-Suspension Overload-SPL–STANCE-Voodoo13-KW and More
With nearly 20 years fine tuning suspension set ups, MA Motorsports would be glad to help you pick out what set up is best for you.
From the daily driven, to full out track car we can provide you with the KNOWLEDGE to set up your suspension properly, we can all put out parts on the internet and have you click the one that is the best price, but we want to help you learn so that you will not only get a great product, but know why you got a great one.
We deal with some of the top names in the industry when it comes to the 370Z suspension, and we want to pass that on to you. Below is just a small sample of the vendors we work with:
PM or CALL 410-593-7080 and Ask for Daelen with ANY questions you may have, we are here to help
COILOVERS
STANCE USA
Stance Super Sport and Super Sport +
The Super Sport is our main flagship line of coilovers. Oversize diameter shocks allow large pistons for ultimate performance and response. 15-way adjustable damping allows the driver to tune the shocks for any conditions and handling characteristics. With huge range of adjustment that can be felt and seen, it offers serious performance for all levels of drivers. Super Sport coilovers are built with highest quality materials and tolerances to ensure durability and performance.
Features:
15-Way Damping Adjustable
Adjustable Camber Uppermount
Pillowball Uppermount
Cold Wound Linear Spring
Inverted Monotube Shocks
Dustboot
Aluminum Collars & Upper Mounts
Height Adjustable Lower Bracket
SWIFT Spring upgrades are available upon request for an additional fee
Stance ProComp2 series
Product Description
Pro Comp2 is our top of the line coilover. The Pro Comp2 features 2-way adjustability, enabling the driver to fine tune compression separately from rebound. An external reservoir is connected to the damper using specially designed fittings that allow the line to swivel and disconnect for packaging and servicing convenience. An optional tool is also available to adjust the gas pressure to give the driver the ultimate adjustment control.
REBOUND
Rebound adjustment controls body roll. It is used to add high speed stability and the rate of weight transfer.
COMPRESSION
Compression controls the roll, pitch and how quickly weight is transferred to each corner. It is effective in adding turn-in response & providing feedback to the driver.
Features:
• 15-Way Damping Adjustable
• Adjustable Camber Uppermount
• Pillowball Uppermount
• SWIFT Spring
• Inverted Monotube Shocks
• Dustboot
• Aluminum Collars & Upper Mounts
• Height Adjustable Lower Bracket
• Helper Spring
• 20-Way Compression Adjustment
http://www.stance-usa.com/main/wp-co...-logos-RED.png
Air Cup Suspension
STANCE Air Cup Suspension [ACS] system is CAD engineered and made from CNC’d billet aluminum and hard anodized. When the air cups are not being used, the coilovers have the same performance and ride quality as if without. With simple click of a button, the STANCE ACS system provide upto 2inches of lift, providing the clearance for the front of the vehicle.
Our kit comes pre-assembled on a lightweight board for easy plug and play install.
*This is an add-on kit to our coilovers. Price does not include the coilover.
Fullkit Include:
• Viair Compressor 380C
• 3gal Aluminum Tank
• Check Valve
• One-Piece Electronic Air Valve
• Bosch Relays
• Deutsch Connectors
• Air Lines
• Two-Way Center Return Micro Switch
• 2x fully assembled Aircups
• Bearing assembly (for McPherson type)
KW
Variant 1
The KW coilover kit Variant 1 "inox-line" is our entry model for more driving pleasure with an attractive and individually adjustable lowering. Due to its high-quality finish, the use of struts made from stainless steel, corrosion resistant springs and bump stops as well as compatible components stands for long driving pleasure - not just the car's life.
Variant 2
Drivers who want more than just an outstanding look and lowering within the TÜV-tested adjustment range, will find the perfect suspension solution with our KW coilovers Variant 2 "inox-line". Not only stainless steel struts, corrosion-resistant components great durability, you have the possiblity to adjust the dampers to your own requirements in rebound (16 clicks) are good reasons to buy KW coilovers Variant 2 "inox-line".
Variant 3
Our engineers have developed a sporty yet harmonious basic setup, as with any KW coilover kit. To be able to guarantee the perfect suspension setup we test on our KW 7-post rig, as well as extensive driving tests on country roads, motorways and even on the Nürburgring Nordschleife. For years, the KW coilover kit Variant 3 "inox-line" is one of the top aftermarket products and is a benchmark for coilovers. It convinces sports car drivers, tuner, large-and small series manufacturer such as Alpina, MTM, Manthey, Oettinger and many more leading companies in the international automotive industry with its damping characteristics, quality finish and durability.
Clubsport
The KW Clubsport coilovers combine KW's high-end racing technology with maintenance-free KW OEM components and TÜV certificate.
This will provide you the ideal product to take full potential of your sports car during track days, sports car driving clinics, enthusiast drives on Grand Prix circuits and on tracks such as the Nürburgring Nordschleife.
BC Racing
BR Series
Our BR Type model is the perfect choice for street driving and the occasional road course or autocross duty. With easily accessible adjustment ***** for fine-tuning your compression and rebound, plus a separately adjustable ride height, having a performance coilover system could not be any easier. You choose how low or high you want your vehicle to sit (no preset ride height here) and our patented concave lower locking ring keeps it locked in securely. Our systems offer optional pillowball mounts to provide the most feedback possible from your suspension, and to sharpen your steering response. Our available front and rear camber plates also allow you to get the perfect alignment setup without compromise. BC Racing offers all of these features while providing a strong, attractive-looking coilover system at a reasonable price.
 Mono-tube shock design
 Full height adjustability through the shock body (not spring)
 30 levels of damping adjustment (compression/rebound)
 Front camber plates are included on all applicable kits
 Rear camber plates included on certain applications
 Custom spring rates available as well as a SWIFT spring upgrade (upon request)
 1 year warranty against manufacturer defect
 Completely rebuildable and individual parts are available separately for purchase
ER Series
Our newest and most advanced model yet is the ER Type coilover system. It features large external reservoirs front and rear, separate rebound and compression adjustment and a twin-piston design. The external reservoirs hold much more oil than conventional coilovers, allowing the unit to operate for much longer before overheating. Additionally, the external reservoirs also house the secondary piston, which allows for the adjustment of compression. This is the perfect coilover system for the person who wants to fine-tune their setup using the separate 30-way rebound and compression tuning dials.
 Dual piston design (1 in reservoir, 1 in shock)
 Full height adjustability through shock body (not spring)
 30 levels of damping adjustment (rebound on top of shock, compression on reservoir)
 Adjustable rear camber plates on certain applications
Tanabe
SUSTEC Pro
USTEC PRO S-0C is for those who desire both high performance and maximum comfort from a suspension system. S-0C is ideal for performance and street applications.
Dispelling a popular belief that a firm or harsh ride is a sign of a performance suspension, the short stroke, shortened case dampener of the S-0C is extremely unique in that its internal construction allows it to deliver superior handling without sacrificing strength or ride comfort.
Unique double-cylinder design allows for full suspension stroke within the shortened shock body while Low-pressure gasses ensure smooth rebound characteristics for additional ride comfort.
SUSTEC Z40
SPRINGS and SHOCKS
Koni
• For more spirited steering & hotter handling, upgrade with a KONI 1140 Sport Kit
• Custom-engineered to fit your year, make and model
• Drops your center of gravity for sportier driving and a more streamlined appearance
• The KONI Sport shocks are fully adjustable—get the ideal dampening rate for the road or the track
• Comes with 4 KONI Sport struts and/or shocks along with a complete set of H&R lowering springs
• Your KONI 1140 Sport Kit includes a Limited Lifetime Warranty
H&R Sport Spring
Eibach Pro Kit
Tanabe
DF210-Max Lowering
NF210-Max Comfort
GF210-Max Agility
ADJUSTABLE ARMS
Voodoo13
CFR Angle Kit
We had a big part in developing this kit with Chris and the guys at Voodoo13, nothing better on the market today.
The CFR (Chris Forsberg Racing) angle kit by VooDoo 13 for the 2009-2014 Nissan 370Z provides all the features every serious drifter needs. It modifies the OEM design to deliver the geometry, strength and adjustability that never driving in a straight line requires.
Voodoo13 Rear Camber Arms
Voodoo13 Rear Toe Arms
SPL
SPL PRO Front Upper Camber/Caster Arms 370Z/G37
SPL TITANIUM Rear Camber Arms 370Z/G37
SPL TITANIUM Rear Traction Arms 370Z/G37
SPL TITANIUM Rear Mid Links 370Z/G37
SPL TITANIUM Rear Toe Arms 370Z/G37
SPL PRO Front Outer Tie Rod Ends 370Z/G37
SPL Eccentric Lockout Kit 370Z/G37
SPC
SPC Performance 09-10 Nissan 370Z Front Adjustable Control Arms
SPC Performance 09-10 Nissan 370Z Rear Adjustable Camber Arm
SWAY BARS and ENDLINKS
Whiteline
Whiteline Nissan 370Z Rear 24mm Heavy Duty Adjustable Swaybar
Whiteline Nissan 370Z Front 27mm Heavy Duty Adjustable Sway Bar
Whiteline Rear Swaybar link kit-Adjustable Ball End Links
SPL
SPL PRO Front Endlinks 370Z/G37
SPL PRO Rear Swaybar Endlinks 350Z/G35/370Z/G37/NB
BUSHINGS
SPL
SPL PRO Solid Differential Mounting Bushings 370Z/G37
SPL FKS Front Lower Arm Bushings (Front) 370Z/G37
SPL PRO Front Impact Bushings 370Z/G37
SPL PRO Solid Subframe Bushings 350Z/G35/370Z/G37
SPL FKS Rear Knuckle Monoball Bushing Set 370z/G37
SPL FKS Rear Upper Arm Monoball Bushings 350Z/G35/370Z/G37
SPL FKS Rear Knuckle Shock Mount Bushings Z33/Z34
Voodoo13
Solid Rear Subframe Bushings
MA-Motorsports is offline
Old 08-03-2015, 06:02 AM
MA-Motorsports
All PMs replied to!
Old 08-04-2015, 06:43 AM
MA-Motorsports
All PMs replied to!
Old 08-05-2015, 10:41 AM
MA-Motorsports
PM me for the best prices!
Old 08-06-2015, 07:14 AM
MA-Motorsports
New day, same great prices!
Old 08-06-2015, 12:23 PM
MA-Motorsports
All PMs replied to!
Old 08-14-2015, 11:57 AM
MA-Motorsports
Weekend Bump!
Old 08-19-2015, 06:33 AM
MA-Motorsports
All PMs replied to!
Old 08-25-2015, 12:39 PM
MA-Motorsports
All PMs replied to!
Old 08-27-2015, 08:13 AM
MA-Motorsports
All PMs replied to!
Old 08-31-2015, 07:54 AM
MA-Motorsports
Monday Bump! All PMs replied to.
04-04-2016 07:52 AM
11-01-2015 05:25 PM
EnjukuRacing
09-30-2015 06:55 AM
codek
09-28-2015 03:03 AM
Quick Reply: From the street to the Track-Suspension Overload-SPL–STANCE-Voodoo13-KW and More
