CZP Soul Function Sale!
Hey Guys, CZP is having a sale for all of Soul Function's Suspension and Chassis Braces for the Nissan 350Z!
_________________________
Soul Function Rear Tie Bar - Nissan 350Z 03-08 Z33
Soul Function’s Rear Tie Bar for the Nissan 350Z stiffens the rear subframe by connecting the left and right lower control arms. The result is improved handling and steering response.
The Rear Tie Bar is constructed from aircraft grade T6061 Aluminum Alloy and is internally reinforced with multiple I-beams. This design maintains strength while reducing overall weight. The bar is powder coated with the signature Soul Function™ Teal.
All hardware is included and installation can be completed with simple hand tools.
Installation can be completed with simple hand tools and stock hardware. Wheel alignment is required after installation of the Rear Tie Bar.
Fitment:
2003-2008 Nissan 350Z
2003-2008 Infiniti G35; Coupe and Sedan; RWD & AWD
2008-2013 Infiniti G37; Coupe and Sedan; RWD & AWD
2011-2012 Infiniti G25; Sedan; RWD & AWD
2014-2015 Infiniti Q60; Coupe; RWD & AWD
2015 Infiniti Q40; Sedan; RWD & AWD
*Does not fit models with 4 Wheel Active Steer (Rear Active Steering)
Soul Function Front Strut Tower Brace - Nissan 350Z 03-06 Z33
Soul Function’s Front Strut Tower Bar for the Nissan 350Z is designed to maintain front suspension geometry by reducing strut tower flex. At only 5.4 pounds, this is an integral upgrade to increase the rigidity, feedback and predictability during hard cornering – all the while keeping your engine bay looking crisp.
The wrinkle-black powder coated bar is made from aircraft grade T6061 Aluminum Alloy and is internally reinforced with multiple I-beams. This design maintains strength while reducing overall weight. End brackets are powder coated with the signature Soul Function™ Teal.
Fitment:
2003-2006 Nissan 350Z (DE Engine Only)
Soul Function Front Lower Tie Bar - Nissan 350Z 03-08 Z33
Soul Function’s Front Lower Tie Bar for the Infiniti V35 Chassis and Nissan 350Z improves front end stability by bridging the front left and right control arms. Combined with our Front Strut Tower Bar, these two upgrades will greatly improve steering feedback and control under hard acceleration and cornering.
The Front Lower Tie Bar is constructed from aircraft grade T6061 Aluminum Alloy and is internally reinforced with multiple I-beams. The bar is powder coated with the signature Soul Function™ Teal.
This product is designed to be fully compatible with all other Soul Function™ braces.
Fitment:
2003-2006 Infiniti G35; Sedan; RWD Only
2003-2007 Infiniti G35; Coupe; RWD Only
Soul Function Front Fender Braces - Nissan 350Z 03-08 Z33
Soul Function’s Fender Brace for the Nissan 350Z reinforces one of the most critical areas of the chassis. The increased front-end frame rigidity allows the suspension to do its job more effectively and greatly improves steering feedback and predictability.
The Fender Braces are constructed from structural carbon steel so you can be confident they will withstand everything you can throw at them. The stamped and welded design maintains strength while reducing overall weight. These braces are powder coated with the signature Soul Function™ Teal.
This brace is designed to be fully compatible with all other Soul Function™ braces.
Fitment:
Soul Function 4-Point Mid Chassis Brace - Nissan 350Z 03-08 Z33
Soul Function’s 4-Point Mid Chassis Brace for the Infiniti V35 Chassis and Nissan 350Z is built for the track- focused enthusiast. This product is fundamental in reducing the overall flex by reinforcing one of the weakest areas of the unibody.
The 4-Point Mid Chassis Brace is constructed from aircraft grade T6061 Aluminum Alloy and are internally reinforced with multiple I-beams. This product is powder coated with the signature Soul Function™ Teal.
Fitment:
2003-2006 Infiniti G35; Sedan; RWD & AWD
Soul Function Rear Lateral Arm Brace - Nissan 350Z 03-08 Z33
Soul Function’s Rear Lateral Arm Brace for the Infiniti V35 Chassis and Nissan 350Z improves back-end stability by connecting the rear lateral links. Paired with our Rear Tie Bar, this brace helps tighten steering response and improve handling.
The Rear Lateral Arm Brace is constructed from aircraft grade T6061 Aluminum Alloy and is internally reinforced with multiple I-beams. The brace is powder coated with the signature Soul Function™ Teal.
Fitment:
