FS/FT: SPL Rear Toe Arms
SPL Rear Toe Arms
SPL Z33 Pro Titanium Rear Toe Arm Links for Nissan 350z 03-08 Z33
For sale at $250
SPL pro rear toe arms replace the stock mid link to provide toe adjustment, for those who have converted to true coilovers in the rear suspension and who no longer need the midlink (spring bucket) to hold the rear springs. Works well for lowered cars or for performance alignments.
Combined with the SPL rear camber arms, this arm will allow for a wide range of adjustment for rear toe and camber. Also pair with the SPL eccentric lockout kit for total rear camber and toe alignment with "zero-slip". Features 1.25″ 4130 chromoly (which has a higher strength/weight ratio than aluminum!) tubing construction for strength, and QA1 Endura 2000 series chromoly rod ends with QA1’s unique maintenance-free injection molded teflon/kevlar lining for long operating life and precise handling. Blue anodized titanium hardware shaves even more unsprung weight from the arms, without compromising strength.
Adjustment specs
Toe adjustment range is +/- 6deg (+/- 7deg w/ stock eccentric bolt) from stock arm (note: toe adjustment affects camber)
For sale at $250
Adjustment specs
felgenwerksusa
06-08-2016 10:23 AM
