FS: (GA) OEM Suspension & Compression Arms, SuperPro Bushings
All items located in Duluth, GA, and are cash only if picked up or plus shipping and PP fees if shipped.
1. The struts are the original units from the factory, removed at 104k miles. The driver's front had some seepage around the piston, but nothing major. Had been that way for at least the last 6k miles or so. Nothing wrong with the other struts. $40.
2. SuperPro Part # SPF2849K. Used less than 6k miles. Removed these from a set of arms after deciding not to use them. They can be adjusted for additional caster gains or to correct suspension geometry on one or both sides. More info: http://www.superpro.com.au/find/supe...rphan-SPF2849K. $40.
3. Factory compression / tension arms arms. They have had the SuperPro bushings pressed out and are ready for fresh ones of your choice! About 100k on both arms, ball joints are in excellent ship with no boot rips or tears, or marred threads. $40.
