Whiteline and ES Bushing Kits offered at B2autodesigns
Hello Members,
Check lower in the post for Whiteline and Energy Suspension parts. We stock at shop. Can ship or pick up.
Whitline Suspension Bushing kits
We stock alot of the Whiteline bushings for the G35 applications:
One of the most noticeable compromises on the 03-06 G35 and 350Z suspension is the soft, hydraulic filled rubber rear subframe bushings that produce flex and squirm under hard acceleration and aggressive driving. To remedy this common problem, Whiteline has developed their G35/350z rear subframe bushing kit, designed around their famous Whiteline Plus series polyurethane bushings. The Whiteline rear subframe bushing kit offers 'no compromise' performance with their unique translucent black polyurethane bushings, specifically created to provide the ride quality of a rubber bushing at low speed yet offer the performance of a solid bushing when under cornering, acceleration and braking load for. These bushings will result in more chassis control and provide a more responsive, predicable and better handling Z or G. The Whiteline Plus rear subframe bushing kit replaces all four points of the rear cradle and includes all the hardware and instructions for a complete out of the box install.
Whiteline Plus 03+ Nissan 350z / Infinity G35 Traction Control Rear Cradle Bushing Kit
Whiteline Infiniti G35/03-09 350Z Rear Diff - Mount Front & RearThe new bushing kit will help control the excessive axle tramp these platforms encounter under heavy acceleration in high horsepower applications. Whiteline’s rigoursly tested low compliance Synthetic Elastomer bushings replace the heavily worn OE front and rear differential mount bushing and dramatically reduce initial torque loss & differential movement during acceleration & deceleration.
Whiteline Compression Rod Bushings 350z/G35 application in stock.
Front Upper Inner Control Arm Bushing Kit (W52988)
Front Lower Shock Absorber - Control Arm Bushing Kit (W52992)
Rear Upper Inner Control Arm Bushing Kit (W62989)
Rear Upper Front Trailing Arm Bushing Kit (W62985)
Rear Upper Rear Control (Lateral) Arm Bushing Kit (W62998)
Rear Lower Rear Control Arm Bushing Kit (W62999)
Rear Lower Front Trailing (Lateral) Arm Bushing Kit (W62997)
Rear Lower Inner Control Arm Bushing Kit (W62996)
Rear Lower Outer Control Arm Bushing Kit (W62535)
Front Lower Inner Control Arm Bushing Kit (W52991)
Energy suspension master kit
Energy Suspension 350z compression rod bushing kit.
Energy Suspension 03-09 Nissan 350Z / 03-07 Infiniti G35 Coupe Black Hyper-Flex Master Bushing Set:
Front Kit Energy Suspension 03-08 350Z / 03-07 Infiniti G35 Front Control Arm Bushing Set front arm kit includes the following bushings: Inner and outer front lower control arm, upper control arm, and compression rod! Red or black finish offered.
Rack and Pinion Bushing Set: Energy Suspension 02-09 Nissan 350Z / 03-07 Infinity G35 Coupe Black or Red
Differential Bushing Energy Suspension 03-09 350Z / 03-07 Infiniti G35 Rear Differential Bushing Set Offered in black or red finish.
Sub Frame Bushing Energy Suspension 02-09 350Z / 03-07 Infiniti G35 Black Rear Sub Frame Set
Lots in stock ready to ship. Pm me or call 813-787-4075 with any questions you might have.
Thanks
Charles
Thanks
Charles
