UTEC 'Upgrade?'
#102
03 CS Track 6MT
on
I tried running to Hyperterminals and it worked like a champ.
There was some weirdness when closing ports but the data streams ran great. Since you have the same configuration and its working I may have to try a dual uart card or another laptop or something.
#103
on
I think that the problem with the wideband may be the baud rate. The UTEC wants to work at 19200 baud only and the wideband only wants to work at 9600 baud. So close yet so far!
I don't think the problem is in the software. Everything works perfect on my laptop, and I'm using teh AEM UEGO at 9600 baud.
As a note, the program uses the Windows standard MSCOMM32.dll provided by microsoft to communicate with the com ports. I've tested this program on 3 different laptops personally, and have had feedback from many other people that do not have a crashing problem. My best guess, is that a Com port is dropping in and out of Windows Device manager, either due to a driver problem or a cable problem, or possibly a device conflict. Since the program uses windows's com port interface, the interface is only available when it's tied to a physical port via the hardware driver. If windows detect a Com port on the computer (like when you plug in a USB->Serial cable), windows loads the driver for the hardware. The logging software, then ties an instance of MSCOMM32.dll to the physical com port for control. The logging software tells MSCOMM32.dll what to send/receive and what com settings to use. If the hardware is removed, or the driver has issues, the device may 'disappear' from windows device manager. The program still has an instance of MSCOMM32.dll running and when it tries to send/receive data, or change settings, MSCOMM32.dll attemps to perform this action on hardware no longer detected in the system...Instant CRASH. This is most likely cause for software crashing when using ANY Com program. I've had MPSUtecLogger crash this way, as well as several other serial based programs when this happens. Causes for this can be anything as simple as a loose USB connection, and vibrations from driving.
-jason
#104
03 CS Track 6MT
on
It isn't crashing, just not working. The AEM data starts and works for like 15 seconds or so and then stops. Yet doing it with two instances of Hyperterminal works perfectly.
I don't think the serial port is disappearing either. I've tried different cables and drivers too. Not sure what to think at this point but I am going to try to get a hold of better serial HW to check it out.
#105
03 CS Track 6MT
on
OK! I finally got it working using my old laptop which has a real serial port (and using 1 usb to serial cable). I guess that the two usb-to-serial cables were not playing together nicely.
I went out and logged some data. Injector duty cycle values are between 5 and 14? Does that make sense?
The boost values (vac) when negative show up as -5.-5 instead of -5.5 (I think that was already reported).
Can timing really be hitting 56.7?? Yikes!
How does it get the Stock ECU timing values that are reported? Does the UTEC provide that?
Got some knock counts too.
#106
on
The UTEC appears to send all the data as ASCII text to the laptop. You can see the data being sent in the main screen towards the bottom of the MPS_UTEC program. It doesn't appear to involve any translation or decoding, but I may be wrong. You can also use hyperterminal to verify the values being reported. Call the UTEC and at the main screen push '1' on your keyboard. It will set the UTEC in to log mode and will start spitting data out the com port to your laptop.
Some things I have noticed, is if you just disconnect the com cable without shutting down MPS_UTEC program and then call the UTEC it will still be in data logging mode. I have also noticed that if you are tweaking the UTEC and you don't exit all the way out to the main UTEC menu the MPS_UTEC won't work, as it can't set the UTEC in to data log mode. It would be nice if the MPS_UTEC program would throw out 2 or 3 'ctrl-x' before sending out the '1' or whatever it is to set it in logging mode. This would force the UTEC in to programming mode unless there are changes that have not been saved, then it would hang on the 'press enter to save' screen.
#107
on
Oh, and congrats on getting it working!
I have been getting lots of knock. I was told by one tuner to free rev the car (In N of course) and adjust the knock settings until you don't get any knock at all. I think my knock is coming from my JWT cams and valve springs.
#108
03 CS Track 6MT
on
Yeah understand but its sort of tough to look at it when driving! I'll have to take a closer look in the driveway when I get a chance (just got it working at lunchtime today).
If someone makes changes and doesnt save them and then goes straight to the mps_uteclogger ...well, thats sort of scary! Mostly I have been just trying to do data acquisition so I can check my a/f, fuel maps, and timing.
I'm not sure I understand what the Save logfile setting is on the main screen. Is realtime data going to that file? I have not looked at it yet but it doesn't seem to get that large. I also get an error once in a while - can't open the file or something but it seems to still log ????
Are you really just going to raise the knock threshold to avoid seeing knock counts? I think my timing is too high in a few places ...where I am knocking.
I wish the UTI software would work with the AEM as it has some nice features such as trigger definitions for starting logs.
#109
on
I was told that there shouldn't be any knock when free reving the motor (assuming you have good a/f). I was getting knock around 2500 RPM with a 14.7A/F and stock timing. I'm 99.9% sure its not knock, but valve train noise that sounds like knock.
#110
You may want to try that to compare .
#114
Originally Posted by mistaboosta
it was being said that UTEC will be able to raise the idle speed soon,
any info about that yet?
Anywho... What about the updates? Any status change?
#116
builtZmotors
builtZmotors
on
+1...any updates? is the software available yet?
also, how does one hook up a wideband to this setup? i read through the several pages of this thread... talk about needing to hook up through a serial port???
pls explain this; how do i setup the utec with an innovate xd-1/lc-1 and the new up and coming software?
Thanks
TODD
Thanks
TODD
#118
Originally Posted by 35ounces
One other simple mod that would be REALLY nice to have would be the ability to LOAD a Log Map. Right now the software allows you to save the log map but there is no way to reload it and view it in the nice colored 2x2 (rpm x Load) layout.
Originally Posted by Havok_RLS2
That would be cool.
#119
on
Thanks
TODD
Thanks
TODD
My AEM wideband has a serial output. I hooked this to a DB9 connector I bought at Radioshack and plugged it in to a 2nd serial port on my laptop (I have a PCMCIA card with 2 ports). The Utec was hooked up to the other serial port.
I'm not sure what the Innovate wideband has, but if it has a serial output it should be a matter of soldering it up to the correct connector.
