Nissan 350Z Discussion forums, Photo Gallery and more...
Go Back   MY350Z.COM Forums > Tech Area > Engine & Drivetrain > Tuning
Old 06-19-2008, 12:04 PM   #1
SamH's Avatar
Question Need Help !?!?!
Hello. I am still kind of new to this forum and modding a 350z in general. As of now, I just installed a JWT Popcharge on my car and Borla Dual Exhaust. I am going to get it tuned and am curious as to what kind of programmer I should get, and what the best bang for the buck is. I'm not educated in tuning at all so if you want to give me advice from the ground up (IE: How it works, what it does) That would be great thanks!!
Here is a picture of my car currently
http://www.geocities.com/kenhornik/350z.html
(For Sale: 2003 18'' OEM Wheels/Tires 0 $600.00 Houston, TX // PM for pics)
__________________
Email: SamHornik@comcast.net 2003 350z Touring Edition - AEM Cold Air Intake // Apexi Power Intake Dry-Flow Filter // Borla True Dual Exhaust // Magnaflow X-Pipe/Muffler // Titek Test Pipes // AAM 5/16'' Plenum Spacer // UTEC TurboXS // Rockford Fostgate Dual 10'' Subwoofers // Rockford Fosgate Amp w/ custom Amp rack and Sub Box // 20'' MRR G5 Wheels
SamH is offline   Reply With Quote
Old 06-19-2008, 12:07 PM   #2
you dont need a tune for just a pop charger and exhaust. you may be able to squeeze a few more hp's but not worth it imo.
LAKERSFAN is offline   Reply With Quote
Old 06-19-2008, 12:12 PM   #3
SamH's Avatar
See... I thought the same thing. But I was reading in multiple forums/websites that w/ the Borla being a true dual w/ 2.5'' piping, you will actually lose some HP, or actualy low-midrane torque because there isn't enough backpressure. Someone told me tuning it would fix the problem.
__________________
Old 06-19-2008, 02:35 PM   #4
Know it all
05Z33's Avatar
First off Borla is 2.25 not 2.5, and If you are looking to tune your car after installing your mods that wouldn't be a bad idea. There are many tunning options on the market. The most popular one is utec. If you don't want a piggy back you can get a reflash from Technosquare or you can pick up an Osiris from Uprev which I think would be the better of the two. Now it's your job to search this forum and decide which one you want. My advise to you is also to get some test pipes and an Xpipe muffler to replace the H pipe on the Borla. Your H pipe will crack eventually.
__________________
Vortech 2.87-GTM pulley mod-Utec tuned by Jeremy at Performance Factory-RC 550cc injectors-Walbro255-Megan headers-res T-pipes-Borla TD with Magnaflow X-pipe/muffler-ACT clutch-Fidanza flywheel-Motordyne 5/16 iso thermal plenum spacer
05Z33 is offline   Reply With Quote
Old 06-19-2008, 03:09 PM   #5
SamH's Avatar
Quote:
Thanks for the info! I'm still kind of the newb scale for car modding. I honestly haven't given 2 shits until recently and am absorbing all the information like a sponge. I pretty much sit up and read about car modding all night. What will the test pipes do? Also, what will the Xpipe muffler do??
__________________
Old 06-20-2008, 03:31 AM   #6
CSF
CSF's Avatar
test pipe replaces your catalytic converters
h pipe / x pipe:
Quote:
For any performance exhaust system, some type of crossover connecting the two sides of a dual exhaust system is important because it acts to balance the two banks of the engine. The common H-style crossover is good at balancing sound pulses between the two halves, but does little to promote scavenging because the exhaust gases tend to follow the path of least resistance, which is straight through each pipe rather than taking the 90-degree turn through the H-pipe into the other half of the system. In an X-pipe system, however, where the two sides of the system intersect, the gasses have no choice but to intermingle as they pass through the junction. This promotes improved scavenging effects by smoothing out uneven exhaust pulses from the engine’s firing order. It also helps quiet down the exhaust, resulting in a mellower, less raspy tone. According to Magnaflow, the faster acceleration of the gasses through an X-pipe causes them to flow in a linear fashion parallel to the walls of the tubing rather than tumbling. This “laminar” flowing gas is much quieter than tumbling gas, resulting in an exhaust tone up to 8 decibels quieter than a traditional H-pipe.
CSF is offline   Reply With Quote
Old 06-24-2008, 09:36 AM   #7
UpRev
UpRev's Avatar
Quote:
Wrong. Any intake will change the way the ECU sees things. The stock MAF will read more or less air depending on the shape and style of the intake. At that point the ECU doesn't read things right and it goes into save the motor mode. It will re-learn in a day or two and start running richer than stock using more fuel and reducing over all power. Thats just how the stock ECU is.
Adding the exhaust usually isn't as big of a deal to the ECU as the only sensors it read from that would truly notice anything are the O2 sensors and as long as the aftermarket exhaust doesn't change the location too much and the install didn't damage the O2 the ECU won't notice it and won't adapt.
A good tune will make more power than pretty much any aftermarket part on these cars. A good tuning software package will allow you to adjust the tune when you add more parts to your car. We're good.
UpRev is offline   Reply With Quote
Old 06-24-2008, 10:46 AM   #8
SamH's Avatar
Thanks for the good info! What do you recommend that I get and do you know of a good place in the houston area to get my Z tuned at ?
Thanks
__________________
Old 06-24-2008, 11:57 AM   #9
UpRev
UpRev's Avatar
Quote:
Thanks
SGP Racing is a good place. http://www.sgpracing.com 281-444-9195
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Advertise on MY350Z.COM - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
Copyright ©2002 - 2008, MY350Z.COM All Rights Reserved.
