Nissan 350Z Discussion forums, Photo Gallery and more...
Go Back   MY350Z.COM Forums > Tech Area > Engine & Drivetrain > Tuning
Old 06-24-2008, 09:56 AM   #1
At Work
nothix's Avatar
UTEC Tuned Results
Finally got around to picking up the TurboXS UTEC and got it installed and tuned by Corr Performance near Baton Rouge.
The Dyno is the heartbreaker Dyno Dynamics
2003 Silverstone 350z 65,000 miles
engine mods:
  • JWT popcharger intake
  • Motordyne 5/16" iso thermal plenum spacer
  • Nismo Cat-Back Exhaust
  • Kinetix Resonated Test Pipes
  • Alphawerks Headers
  • WRP Underdriven crank pulley
The dyno didn't get an accurate reading on the pre-tune dyno, and we didn't realize it until after tuning had begun. So, I don't have a good pre-tune chart.
the chart:
when trying to lean out the AFR, the rate would spike up near 6000 rpms.
after playing with the AFR a good bit, decided that it wouldn't be going away. I'm pretty sure this problem was caused by the AT.
Let me know what you guys think.
PS the whp vs wtq will be up soon
__________________
-|-03SS-|-JWT-|-EBC-|-MotorDyne-|-Kinetix-|-Nismo-|-WRP-|-Hotchkis-|-Rota-|-Vredestein-|-Alphawerks-|-TurboXS
Tuned by Corr Performance
nothix is online now   Reply With Quote
Old 06-24-2008, 11:00 AM   #2
what did they do to your AFR? thats absolutely terrible. the majority of that afr curve belongs on a turbo car at 35psi, your afr should be closer to 13-13.5:1. the "lean spike" is the best spot on that fuel curve. no joke, i would be taking that thing back for them to do right
Hoooper is offline   Reply With Quote
Old 06-24-2008, 12:06 PM   #3
LivingDeadGirl
gothchick's Avatar
^^^ Z's and G's don't do 35psi... More like 19 or 20 tops. Lol. Guess you maxima does though.
__________________
2006 6MT GT Silverstone, Nismo floormats - Coming soon: Nismo license plate frame
gothchick is offline   Reply With Quote
Old 06-24-2008, 01:18 PM   #4
Quote:
what? i never said it did 35psi, said that afr would be good for it...not sure whats got your panties in a bunch.
ps: z's and g's could do 35 psi, just nobody has built that design of motor for one. and there are z's running 29 psi, the intense car comes to mind...
so youre hating on my car cause i have the same engine and were in the engine discussion forum? makes sense
Old 06-24-2008, 01:23 PM   #5
shift_mygtr
blasian's Avatar
I was there when they tuned it... we are not sure why the spike happened but it seemed like it was something else and not the tune, I've never seen that before.
Any thoughts?
__________________
www.my350z.com/ - www.boostedimports.com - 2003 Daytona Blue Touring - Stock - Team DNF - Official grape drinker, mic dropper and informer that bird is the word
Quote:
Originally Posted by bboypuertoroc
where where you?
They stole my grape drank
blasian is offline   Reply With Quote
Old 06-24-2008, 01:28 PM   #6
where was the afr taken from? that curve kinda makes me think that it was reading incorrectly, cause if you look at the graph, the curve does seem to change at all when the afr curve changes, which it should. the shape of the curve ought to change when the shape of the afr curve changes, which only happens a little bit where the spike is. he doesnt have a WBO2 i take it?
Old 06-24-2008, 01:30 PM   #7
shift_mygtr
blasian's Avatar
Quote:
Nope.
It was taken from the wideband in the exhaust. Its seemed to work for me when I got my AFR checked with it
When my car was running rich
__________________
where where you?
Old 06-24-2008, 01:32 PM   #8
Asian Invasian's Avatar
Not quite 250 damn haha.
__________________
Black 350z: Bassani | ARC | ROTA | 8000k | Hotchkis |
Asian Invasian is offline   Reply With Quote
Old 06-24-2008, 01:35 PM   #9
Quote:
Originally Posted by blasian
Nope.
was it actually in the exhaust or in the tailpipe?
lol. it starts out good but
Old 06-24-2008, 01:37 PM   #10
shift_mygtr
blasian's Avatar
In the tailpipe as it was the same with mine. My AFR went to crap
I was getting a tune but I think I was curious to how crap my AFR was. I wish I had the other graph which was probably a better indicator of how it should level off. I don't have it on me unfortunately.
I doubt it's the wideband though, it did it for every run. Is it an auto thing
__________________
where where you?
Old 06-24-2008, 01:43 PM   #11
nah its not related to the auto, unless it slipped a little bit right there, which i highly doubt. being in the tailpipe though, makes that afr REALLY bad, since a tailpipe reading is usually 1-1.5 pts leaner than actual. i would tend to think that it was an exhaust related problem if the power hadnt dipped a little there too. possibly an MAF or injector related issue. kinda hard to say
Old 06-24-2008, 01:45 PM   #12
shift_mygtr
blasian's Avatar
Not sure what was causing it but there seemed to be no way to get rid of it from tuning it.
__________________
where where you?
Old 06-24-2008, 02:12 PM   #13
At Work
nothix's Avatar
I'm not too familiar with the tuning process, but I'd love to hear more opinions from people.
I figured I would make more power. Hopefully the TQ curve will tell us something else.
edit: free picture with with bump
__________________
Old 06-24-2008, 02:15 PM   #14
Judging by your mods I would assume you would have made more too. I made 242 with everything you have EXCEPT for UTEC + Tune, Crank Pulley, and headers.
I was super disapointed with my numbers even though I didn't have a baseline. I figured I would just order some 4.083 gears and call it a day.
__________________
Old 06-24-2008, 02:19 PM   #15
frankie945's Avatar
I bet u would get around 255 260 if you get your afr right, make sure you have a fresh set of plugs for the next dyno..
__________________
04 Base, TN, 3 1/2'' custom single exhaust, JWT Clutch/Flywheel Blitz EBC, Utec,Tuner Pro, 600cc deatchworks, Walbro 255, Snow Performance Stage II water/meth, And alot more...New #'s coming soon. Right now 361whp 388wtq on 7.2 psi. Everything installed by me Tuned by Auto Motion Louisville KY
frankie945 is offline   Reply With Quote
Old 06-24-2008, 02:31 PM   #16
At Work
nothix's Avatar
Yea the plugs are a few months old.
Probably could have used some fresh oil.
And I might have an exhaust leak somewhere.
Gonna jack it up and look around this weekend.
Any tips for finding exhaust leaks? bring it to an exhaust shop?
__________________
Old 06-24-2008, 02:33 PM   #17
shift_mygtr
blasian's Avatar
What exactly what were you expecting HP wise? Please don't say 284
You won't know anything until you take it to the track regardless.
__________________
where where you?
Old 06-24-2008, 02:41 PM   #18
look for carbon deposits on the exhaust and listen to it running. if you hear something, try to pinpoint it. if its been leaking for any period of time it should be easy to spot.
blasian: if i was him id expect more too. sure its an auto but his mods should be good for an easy 255. that tuner really likes the mixture rich and its killing the power
Old 06-24-2008, 02:43 PM   #19
Nothix, get that other stuff sorted out like u told me on AIM and bring it back.
As I mentioned to you after we finished that day, if you are unsatisfied or think we can improve on the tune, then by all means set up an appointment and we will tweak it free of charge.
Alberto
__________________
'04 Dyno Dynamics 450 single retarder & axle dynamometer. EFI101 graduate, AEM EMS factory certified
El Verdugo is offline   Reply With Quote
Old 06-24-2008, 02:47 PM   #20
shift_mygtr
blasian's Avatar
So tell me what type of power he should be putting down?
__________________
where where you?
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
