Nissan 350Z Discussion forums, Photo Gallery and more...
Go Back   MY350Z.COM Forums > Tech Area > Engine & Drivetrain > Tuning
Old 07-14-2008, 07:51 PM   #1
kenpo_350Z's Avatar
Tune Noob
With my current mods (in my sig) would it beneficial for me to get a tune? Is this something that can be done at a nissan dealer? I just read the other post made about his friend getting the JWT done. Doesn't sound like it but I don't have any other shops around.
What are my options and what are the cheapest priced tunes?
Thanks for the help.
__________________
2004 Silverstone Touring ZR 6 Spd, burnt orange/black seats, JDM Clear Reflectors, S2K Antenna, RS*R Exmag GTII, Motordyne 5/16 Iso Thermal Spacer, JWT Popcharger, Unorthodox Racing Underdrive Crank Pulley, 30% Tint, tail light overlays, Hawk HPS pads.
kenpo_350Z is offline   Reply With Quote
Old 07-15-2008, 01:52 AM   #2
xav_350z's Avatar
Nissan dealer can adjust timing with their scanner (Consult II) but not sure about the A/F ratio.
You can go with the UTEC, or with Osiris, or the Cobb access port...
__________________
Vortech S/C wiz 3.0 pulley -UTEC - tanabe GF210 springs - B&M short shifter - HKS Hi-Power True Dual Ti Exhaust - Crawford HFC - JWT Flywheel - NISMO Clutch - Nismo brake Pads - Nismo shift knob - Nismo thermostat - MD 5/16 plenum spacer - 18' SSR D5R wheels - Varis Airduct - K&N air filter Snow performance WI kit - Zeitronix Wideband
xav_350z is offline   Reply With Quote
Old 07-15-2008, 06:24 AM   #3
kenpo_350Z's Avatar
If a buddy of mine has a cobb access port for his Sti, is there a way to just download a tune for mine and use his? I don't know how all this works.
__________________
Old 07-15-2008, 07:14 AM   #4
Quote:
negative. the AP is model specific and cannot even be used on seperate cars of the same type. if i am not mistaken, during the initial setup, the AP reads the VIN or some other type of identifier and will only make changes for that particular car.
sloppymax is online now   Reply With Quote
Old 07-15-2008, 07:17 AM   #5
kenpo_350Z's Avatar
Okay thanks, how much is a cheap reflash and where do you go for that? I don't have anything where I am at. If it is even worth doing with the mods I have.
__________________
Old 07-15-2008, 10:22 AM   #6
not worth it... if you plan on doing more breather mods, just wait... if you are done just enjoy the car - a tune at this point would be a waste of money.
OCG35 is offline   Reply With Quote
Old 07-15-2008, 11:27 AM   #7
kenpo_350Z's Avatar
Yeah I want to do HFC's at some point. I am enjoying the car with the mods. They have improved it a little. I am def. not going to do headers so after the HFC's it might be time for the tune then.
Thanks
__________________
Old 07-15-2008, 12:37 PM   #8
UpRev
UpRev's Avatar
Quote:
bzzt wrong
UpRev is offline   Reply With Quote
Old 07-15-2008, 12:39 PM   #9
UpRev
UpRev's Avatar
A reflash would be a bad idea if you had no way to adjust it in the future when you change the mods on your car. Luckily we're here. You can buy a basic flash from us, and get three free eTunes. Usually people will use one eTune to make the basic reflash work for their particular car as a basic reflash doesn't sit well with all vehicles. After that you'd have two free eTunes left that you could use whenever you change the mods on your car, or if you move to a drastically different climate or altitude.
Read through the 500 pages of our thread if you want to see what people say about the quality of our product
Old 07-15-2008, 12:50 PM   #10
I was going to send this by PM but it appears that function is disabled. Can you provide a brief summary as to the process of creating a flash? I assume the end user monitors and logs certain parameters then sends that info in for one of the included 3 eTunes? Then you design a flash gears around those parameters then it is emailed and uploaded to the car through the software. I just want to make sure I understand the process before I decide to go with one over the other. I did check your site but was still unclear. Thank you in advance.
Old 07-15-2008, 12:55 PM   #11
bzzt wrong
care to elaborate?...
Old 07-15-2008, 01:53 PM   #12
UpRev
UpRev's Avatar
I did, one post up.
Our tune is never negated by upgrades. Our tuning abilities are even worth while on a completely stock vehicle. It's especially important on vehicles with mechanical advantage upgrades as the stock ECU is expecting X and the sensors are then telling it Y. The stock ECU then compensates for safety, meaning the car will run richer, and often times pull ignition. So a tune anytime you add hard parts (mechanical advantage) is a good idea. Having one that you can update at will is even better.
Old 07-15-2008, 01:59 PM   #13
I did, one post up.
I have Osiris... I'm all to familiar... however, I stand by my advice to the post I responded to.
Old 07-15-2008, 02:03 PM   #14
I think a reflash on a stock car might be worth it, given what even the standard flash does.(ala Technosquare L-spec) It's up to the purchaser if the cost/benefit is right.
But the great thing about UpRev is that reflashes are free for the 1st three. Great if you have a wideband and can avoid having to dyno to gather the info for UpRev to create another flash for ya.
Jeff92se is offline   Reply With Quote
Old 07-15-2008, 02:08 PM   #15
UpRev
UpRev's Avatar
Quote:
We generally try and start with as close as possible of a match for your model and year of car with the mods you list. We don't always have an exact match, but for the 350Z/G35 we're usually pretty close. We make the base roms from cars that we have actually dyno tuned. Those tunes while close as possible are never perfect for your car, so we try and get people to send back a log file from their car so that we can verify how close the flash is to working on your particular car. From those logs we can adjust AFR trims and on the rare occasion we'll even have to back down some timing as all cars are different. We then e-mail the updated tune back to you so that you can flash your car with something based on your car.
Is it perfect? No. But we're going to be as close as possible without having to dyno tune your car, and we're the only company that does this service without hesitation and free that I know of. The purpose behind giving three free eTunes and not just one, is that we want customers to feel good about upgrading their cars further, they don't have to concern themselves too much about how well their car is going to run if they modify something. We're car geeks to the core here and we never stop working on our own cars, we don't expect our customers do either.
Old 07-15-2008, 04:52 PM   #16
kenpo_350Z's Avatar
I will have to check out your site and read what this is all about. Sounds like this is the way to go. How can you go wrong with three free etunes? Does the site explain exactly what you have to buy to get the info to the ecu? I do not have a wide band or any tuning device. We do not even have a dyno here. I am very interested though now.
Thanks for the information and replies.
__________________
Old 07-16-2008, 02:46 AM   #17
zerosec's Avatar
Uprev,
Tried PMing you but couldn't, is there an email I can contact you at? Thanks
zerosec is offline   Reply With Quote
Old 07-16-2008, 11:24 AM   #18
UpRev
UpRev's Avatar
Quote:
Originally Posted by zerosec
Uprev,
info@uprev.com
rich@uprev.com
support@uprev.com
orders@uprev.com
etc
Old 07-17-2008, 02:18 AM   #19
zerosec's Avatar
10x
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Advertise on MY350Z.COM - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
Copyright ©2002 - 2008, MY350Z.COM All Rights Reserved.
