Nissan 350Z Discussion forums, Photo Gallery and more...
Go Back   MY350Z.COM Forums > Tech Area > Engine & Drivetrain > Tuning
Old 07-17-2008, 08:25 AM   #1
UTEC Greddy (750cc) Base Map.
The Greddy Base MAP found on Turbo XS website.
http://www.turboxs.com/downloads/350...TT750cc28d.TXT
Is this safe to use for initial startup for the Greddy TT with 440cc Injectors, Test Pipes, HKS Exhaust, and Plenum Spacer? What about driving to another location? Stay out of boost?
Thanks!
RandomHer0 is offline   Reply With Quote
Old 07-19-2008, 09:55 PM   #2
you should be fine.
3.6z is offline   Reply With Quote
Old 07-20-2008, 11:47 AM   #3
Madelinot's Avatar
You should be running rich with that map. But every car is different. For example, starting from the base APS map on the turboXS Website, I had to add a lot of fuel and back off the timing a bit to make it safe on my car. In any case, if you stay out of boost, you should be fine. You might have to put you fuel 0% columns all to zeros.
Later,
__________________
2004 G35 Coupe, APS Intercooled Twin Turbo, APS 2.5" TD exhaust, Labree testpipes, Crawford Plenum, CoolingMist water-methanol Injection Kit, ATS twin carbon clutch, Kuruma Z front bumper, Impul side skirts.
Madelinot is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Advertise on MY350Z.COM - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
Copyright ©2002 - 2008, MY350Z.COM All Rights Reserved.
