Nissan 350Z Discussion forums, Photo Gallery and more...
Go Back   MY350Z.COM Forums > Tech Area > Engine & Drivetrain > Tuning
Old 07-30-2008, 03:00 PM   #1
Help! Innovate LC-1 AFR problem
hi i just intalled in my Z (just mod MD 5/16" Spacer, O2 Exahust) the innovate LC-1 innovate A/F gauge, and dunno why but it shows when starts engine 7.5 ~ 10.3 AFR, but i have also apexis turbo timer and with that it shows 13.5 ~ 16 AFR, so anything is wrong with installaton? i'm worry because in next week i'm going to install the vortech supercharger, so i follow the instructions for the innovate AF LC1
First disconnect the sensor from the exhaust, later i put in ACC to supply 12V to LC-1 for 20 seconds, lateri turn it off and then the sensor is expose to the AIR for calibration, then i switch on and wait like 2 minutes till the LED lights comes steady, so i did twice this all instructions but still the same, so anyone can help me? thanks
wenlipai is offline   Reply With Quote
Old 07-30-2008, 03:12 PM   #2
you did the calibration in open air right? as in not installed in the exhaust yet?
Hoooper is offline   Reply With Quote
Old 07-30-2008, 05:52 PM   #3
turbotoy's Avatar
Yes! Must calibrate and make sure all our grounds are good grounds. They go on and on about grounds on the Innovate forums.
__________________
2006 Enthusiast, Revup V2, Magnetic Black, Stillen duel Exhaust, AEM cold air, Stillen headers, Kinetix HFC, Motordyne 5/16" spacer, Motordyne Mrev2, UPRev Osiris 1982 Toyota Corolla SR5, 3tgteu fully built, Haltech e6s AE86 suspension, and much more!! 1980 Toyota Corolla with a 1UZFE lexus V8 Autronics SM4 ready for road race!!!
turbotoy is offline   Reply With Quote
Old 07-30-2008, 10:39 PM   #4
Quote:
yeah i did calibrate in open air , not installed in exhaust,
Old 07-30-2008, 10:40 PM   #5
Quote:
yeah i did calibrate it twice and the same numbers, yeah i did put all grounds in it but still the same, but can you give me an example where is the best ground to put it on?
Old 07-30-2008, 10:44 PM   #6
jeffie7's Avatar
One of the black wires is for calibration, you ground it to "reset" the sensor. I hooked it up with the other grounds and boy did that screw with my readings.
__________________
DNF fUzZyBuNnYbAlLz iny0mouf
jeffie7 is offline   Reply With Quote
Old 07-31-2008, 08:53 AM   #7
Quote:
hi i did add dat ground to a LED push bottom for reset , and still the same, today i check all Grounds to fit in a chassis lug, but still the same numbers, 7.5 ~ 10.3 AFR, i pushed the bottom for re-cablibrate Free Air Calibration, but still the same numbers man, i suckss!!! anyone can give me more information? thanks you all and i appreciate for your advices
Old 07-31-2008, 10:34 AM   #8
UpRev
UpRev's Avatar
Contact Innovate, or check on their forums. I'm sure the people on their forums will have a better idea and sooner.
Also are you sure the LED push button isn't allowing a ground in and of itself? I'd try using a two pole momentary non-lit button to make sure.
UpRev is offline   Reply With Quote
Old 07-31-2008, 11:35 AM   #9
turbotoy's Avatar
Best ground is the engine block or batt negative.
__________________
Old 07-31-2008, 07:10 PM   #10
hi, yeah i did put the ground on chassis on a lug with a nut, but still the same, but i'll calibrate again tomorrow and i'llcheck if works.
Old 08-01-2008, 02:33 PM   #11
turbotoy's Avatar
Chassis ground may not be good enough. As an experiment run a wire to the negative part of the battery. Also you should have more than one ground. You have the ground for the gauge. You also have the grounds for the LC-1 itself. You also have the analog output grounds. The gauge can be chassis. But the LC-1 needs to be grounded to batt. neg. Again this information is from the Innovate forums they are very explicit about grounds and ground offsets.
__________________
Old 08-01-2008, 02:38 PM   #12
hi thank a lot for your advice, so i connect LC-1 GND to battery negative, Gauge GND and analog output GND in Chassis ? like this? i'll try it in a few hours thanks
Old 08-01-2008, 03:19 PM   #13
i have mine connected to ECU ground (soldered to wire). works great, although most people would say not to do that
Old 08-03-2008, 01:44 PM   #14
hi all !~! yeah it works!!! i connected to the battery GND and also there are 2 cables for output Yellow and brown, so i connect the brong one (output 2) and calibrate free air, and did work! so right now my AFR is between 13.7 ~ 15.8 AFR but one question when i accelerate the pedal it shows aroung the 13.7 ~ 15.8 AFR but when i let the pedal (no accelerate) the AFR is like so high 18 ~ 22.4 AFR buy i thinkthat s maybe because im not giving fuel, right?
Old 08-03-2008, 04:43 PM   #15
you mean let off the pedal when youre moving and in gear?
Old 08-03-2008, 07:05 PM   #16
yeah!! when i let off the pedal in a gear, so is that normal?
Old 08-11-2008, 10:45 PM   #17
turbotoy's Avatar
When you let off the pedal in gear the injectors should shut off. So you should read a very lean AFR.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Advertise on MY350Z.COM - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
Copyright ©2002 - 2008, MY350Z.COM All Rights Reserved.
