Nissan 350Z Discussion forums, Photo Gallery and more...
Go Back   MY350Z.COM Forums > Tech Area > Engine & Drivetrain > Tuning
Old 08-25-2008, 06:51 PM   #1
hr2burn's Avatar
Someone look @ this UTEC log?
My car has been running fine. Slowly in the hotter weather it was really stuttering until UTEC kicked in...thought it might the lower density of the air.
However I haven't been driving it and now it's cold out and is HORRIBLE!
Seems to run normal til the UTEC kicks in about 2800rpm. Then it bucks, kick and all round sucks! If I push it a bit it will gain boost, altough I hear the turbo spooling more than what I see my boost gauge read. Cleaned the MAF (yes with MAF cleaner) Checked for broken pipes/ loose pipe clamps. I have never data logged before, but I see that load doesn't seem to go over 30. Timing seems really advanced for the manner I'm driving it.
Anyone want to take a look? Keep in mind I would start logging, pause then do it again.
Thanks, Sean
http://home.comcast.net/~hr2burn/prob1.TXT
Am I seeing Throttle postion @ zero?
__________________
Turbonetics, Fujitsubo, Act, JWT, Kinetix,TurboXS, Tial, Ruff Racing, Nitto Invo, GReddy, AUT, AEM, Blitz436rwhp-400tq @ 9.5lbs
hr2burn is offline   Reply With Quote
Old 08-26-2008, 04:18 AM   #2
armt350z's Avatar
Check your temp compensation page, if all the Values are 0 then that is probably your problem.
armt350z is offline   Reply With Quote
Old 08-26-2008, 06:47 AM   #3
LivingDeadGirl
gothchick's Avatar
Do you have a wideband? That would be very helpful to include in the logs. Also, log 1 is the best for logging because it gives you the most info. Lastly, it looks like most of your logs are showing closed loop. Meaning the ecu is driving the car not UTEC... Try to log with your TPS and Load values from 25 and above. I assume your threshold cutoff is 2000rpm and 25%TPS? Your open loop timing curves look smooth though. No knock. AFR would be good to know.
__________________
2006 6MT GT Silverstone, Nismo floormats - Coming soon: Nismo license plate frame
gothchick is offline   Reply With Quote
Old 08-26-2008, 08:04 AM   #4
hr2burn's Avatar
Yeah +1 on the AFR, sadly I do not have one. I know with my injectors and while the stock ECU if still running the show I am like 8:1. I feels like it is running seriously rich. I am having a real hard time giving it more throttle or getting up to a higher load...it about threw my wife out of the car while she was holding the lap top. I guess I will have to find a way to get it to the tuner....
I will try another log using logger #6 if this does give more info. What I did on my first attempt is a bit messy.
THANKS ALL!
__________________
Old 08-26-2008, 08:35 AM   #5
athenG's Avatar
Use logger 1 for the most complete logs. Also post your map so we can take a look at your fuel and timing. What size injector are you using? Were did you get the Map? Was this tuned by a pro shop or you just got utec and installed it and fired it up? To many things has to be set. Are you using a Map Sensor?
I strongly suggest to bring this to a pro shop since you are not really proficient with utec yet. What is your Min/Max Map value? I see you are hitting load 40 at 0 psi. what is your target max boost anyways? I think your parameters are not set right.
athenG is offline   Reply With Quote
Old 08-26-2008, 08:37 AM   #6
athenG's Avatar
THANKS ALL!
You should tune if you don't have a wideband... Use logger 1 and post here, I'm thinking utec is kicking early and your A/F all over the place.
Old 08-26-2008, 08:58 AM   #7
hr2burn's Avatar
Will do tonight AthenG...thanks again. For what it's worth, I DO NOT screw with the UTEC/tuning. I have been to the tuner everytime I do a mod. I am confused how something within the tune could change. That is what it seems like though...
__________________
Old 08-26-2008, 09:03 AM   #8
hr2burn's Avatar
380cc, Professional tuner,MAP sensor (yes), only one mapo needed, dont need low high...my max is 9.5 to 10lbs
__________________
Old 08-26-2008, 09:21 AM   #9
athenG's Avatar
This is tuned by a pro? WTF!! You are hitting load 30 at vacuum... Let the ECU control it at vacuum and Utec take control at above 0 or 1psi. No point of letting Utec take control below that since utec RESOLUTION is ver limited. Yes you only need one map but your Min/Max Map value isn't set right. If you max boost is 10 psi then I'll set the Max Map value to at least 11 or 12 psi just to give you 1-2 psi incase you overboost and make sure your have the overboost cutoff set to what ever is your max map value.
Old 08-26-2008, 11:28 AM   #10
hr2burn's Avatar
my injectors are @ 97% duty cycle...If I see much more boost I'm toast. The utec is kicking in sooner beause of how rich I run when the ECU is thinking it's dealing with 280cc injectors. So you think the is something really wrong with this log...or just different? Again I will post a proper one tonight.
__________________
Old 08-26-2008, 12:12 PM   #11
athenG's Avatar
You have to tune your 0 column (Fuel Map) because that is what the ECU will run when you are out of boost. That is how your tuner scale for you bigger injector. I think you tuner don't really know how to tune utec. Your boost controller will set your boost and not the Map in you utec. I just said set you max map value to 11 or 12psi so that in case you get a boost spike then you are still tuned for that. If you keep getting boost creep then the culprit is your boost controller or WS spring.
Like I said, resolution is very limited in Utec so you dont want to use some of it when you are still in Vacuum were the ECU is well capable of handling it. Heck, some people here don't even let Utec take control until past 3psi.
Old 08-26-2008, 02:17 PM   #12
hr2burn's Avatar
Wow, that is all very interesting, so could the 0 column help with the richness I am dealing with prior to when the UTEC takes over?
__________________
Old 08-26-2008, 04:05 PM   #13
athenG's Avatar
Yes, you tune the 0 column in your fuel map to scale your bigger injector.
Old 08-26-2008, 05:52 PM   #14
hr2burn's Avatar
Well f me....Seemed kinda normal tonight...WTF?
Heres a SHORT boost log:
RPM MAP MAF TPS Site Count Inj#1 Ign#1 Inj#1 Ign Fuel MAF
psia V % mS deg duty deg % V
978 -11.0 1.35 7 00 00 1.55 +17.8 1.3 ECU. +0.0 1.39
879 -10.4 1.50 14 00 00 1.98 +31.1 14.7 ECU. +0.0 1.84
859 -9.0 1.84 13 00 00 1.37 +30.5 14.7 ECU. +0.0 1.86
966 -7.7 1.82 13 00 00 3.51 +25.5 2.7 ECU. +0.0 1.86
1103 -7.0 1.82 13 00 00 4.10 +24.9 3.3 ECU. +0.0 1.90
1259 -7.0 1.84 13 00 00 4.16 +28.4 3.9 ECU. +0.0 1.90
1417 -7.2 1.82 13 00 00 4.07 +31.6 4.3 ECU. +0.0 1.86
1513 -7.7 1.74 13 00 00 3.94 +32.4 4.6 ECU. +0.0 1.84
1582 -8.1 1.72 13 00 00 3.62 +33.4 4.6 ECU. +0.0 1.80
1606 -8.4 1.80 13 00 00 3.53 +33.5 4.6 ECU. +0.0 1.86
1607 -8.5 1.82 13 00 00 3.50 +33.5 4.6 ECU. +0.0 1.84
1577 -8.6 1.74 13 00 00 3.32 +33.6 4.3 ECU. +0.0 1.86
1521 -8.6 1.76 13 00 00 3.29 +34.7 4.2 ECU. +0.0 1.82
1467 -8.5 1.78 13 00 00 3.28 +33.6 4.1 ECU. +0.0 1.86
1420 -8.4 1.80 13 00 00 3.31 +32.5 4.0 ECU. +0.0 1.92
1395 -8.2 1.84 13 00 00 3.50 +32.6 4.1 ECU. +0.0 1.88
1388 -8.1 1.80 14 00 00 3.57 +33.5 4.1 ECU. +0.0 1.86
1434 -8.1 1.80 14 00 00 3.48 +32.3 4.0 ECU. +0.0 1.84
1507 -8.1 1.80 14 00 00 3.42 +33.6 4.1 ECU. +0.0 1.84
1500 -8.2 1.82 15 00 00 3.36 +33.5 4.1 ECU. +0.0 1.98
1536 -8.0 1.96 17 00 00 3.64 +33.5 4.6 ECU. +0.0 2.00
1597 -7.5 2.09 19 00 00 3.98 +33.3 5.1 ECU. +0.0 2.19
1676 -7.0 2.21 19 00 00 4.24 +31.5 5.6 ECU. +0.0 2.33
1717 -6.6 2.25 20 00 00 4.78 +30.3 6.8 ECU. +0.0 2.31
1772 -6.3 2.33 24 00 00 4.70 +30.5 6.8 ECU. +0.0 2.54
1850 -5.2 2.54 25 00 00 6.01 +28.4 11.2 ECU. +0.0 2.66
2004 -4.8 2.54 26 00 00 6.20 +26.3 10.1 ECU. +0.0 2.66
2111 -4.5 2.66 34 00 00 6.20 +26.4 10.6 ECU. +0.0 2.82
2275 -3.9 2.78 38 00 00 6.85 +25.2 12.7 ECU. +0.0 2.96
2487 -3.6 2.84 46 00 00 6.97 +26.2 14.0 ECU. +0.0 3.05
2725 -3.4 3.01 52 00 00 7.09 +27.4 15.5 ECU. +0.0 3.15
2957 -3.3 3.11 53 00 00 7.24 +24.2 17.1 ECU. +0.0 3.23
3147 -3.2 3.19 56 00 00 9.55 +25.3 25.9 ECU. +0.0 3.29
3239 -2.9 3.21 57 00 00 8.61 +26.2 23.4 +23.0 +0.0 3.47
3135 -2.8 3.19 57 20 00 9.06 +25.3 23.3 +22.9 +0.0 3.45
3008 -2.4 3.23 56 20 00 9.49 +25.3 23.6 +22.8 +0.0 3.35
3097 -2.3 3.29 61 20 00 9.42 +25.1 24.5 +22.7 +0.0 3.41
3363 -1.9 3.43 69 30 00 8.98 +25.3 25.6 +22.5 +0.0 3.66
3561 -1.3 3.47 73 30 00 8.52 +25.2 25.3 +22.0 +0.0 3.78
3627 -1.0 3.66 73 30 00 8.86 +24.1 26.9 +21.3 +0.0 3.82
3800 -0.6 3.72 73 30 00 9.55 +24.1 30.7 +20.1 +0.0 3.92
4025 -0.5 3.92 75 30 00 10.25 +23.9 34.6 +19.0 +0.0 4.17
4224 +0.1 4.05 76 40 00 11.09 +22.9 39.2 +17.9 +0.0 4.31
4420 +0.5 4.03 76 40 00 12.08 +22.0 44.8 +16.9 +0.0 4.41
4623 +1.4 4.29 76 40 00 13.24 +21.0 51.7 +16.2 +0.0 4.47
4887 +2.2 4.54 76 50 00 14.62 +23.0 60.1 +15.3 +0.0 4.60
5144 +3.2 4.60 75 50 00 16.27 +21.8 70.1 +14.3 +0.0 4.60
5367 +3.9 4.72 74 60 00 16.68 +19.4 75.2 +14.3 +0.0 4.60
5592 +4.1 4.88 71 60 00 16.37 +20.6 77.5 +15.3 +0.0 4.60
5847 +3.3 4.84 64 50 00 15.22 +20.7 74.8 +18.0 +0.0 4.60
5952 +0.8 4.39 36 40 00 14.92 +21.7 73.2 +21.3 +0.0 4.35
5428 -3.8 2.35 0 20 00 10.48 +29.1 46.7 +21.3 +0.0 2.29
5096 -8.6 1.58 0 10 00 10.17 +33.0 42.5 +21.0 +0.0 2.13
4810 -10.6 1.50 0 10 00 10.33 +33.8 41.1 +17.0 +0.0 2.07
4553 -11.2 1.94 20 00 00 1.59 +38.0 5.9 +17.2 +0.0 2.43
4079 -7.7 4.43 100 00 00 10.16 +14.1 64.1 ECU. +0.0 4.21
4110 +0.3 4.05 100 40 00 11.99 +24.1 40.9 +17.6 +0.0 4.17
4203 +1.7 4.09 102 50 00 14.00 +23.0 49.2 +15.7 +0.0 4.41
4312 +2.8 4.37 102 50 00 15.11 +21.1 54.1 +14.8 +0.0 4.45
4214 +3.9 4.47 101 60 00 15.53 +23.1 54.0 +13.7 +0.0 4.60
4235 +5.2 4.49 101 60 00 16.11 +23.0 57.6 +12.7 +0.0 4.60
4456 +5.4 4.66 101 70 00 17.91 +19.5 67.9 +12.5 +0.0 4.60
4528 +5.9 4.64 97 70 00 18.75 +20.8 71.1 +12.2 +0.0 4.60
4688 +6.1 4.84 96 70 00 18.84 +21.0 73.6 +12.2 +0.0 4.60
4803 +6.1 4.80 95 70 00 18.95 +21.0 75.9 +12.2 +0.0 4.60
4923 +6.2 4.88 91 70 00 18.92 +23.1 77.3 +12.1 +0.0 4.60
5042 +6.2 4.90 84 70 00 18.74 +22.0 79.1 +12.2 +0.0 4.60
5151 +6.0 4.74 76 70 00 18.62 +21.8 79.5 +12.4 +0.0 4.60
5200 +4.8 4.66 64 60 00 17.33 +19.4 75.2 +13.2 +0.0 4.60
5307 +2.2 4.43 43 50 00 14.80 +20.8 66.1 +17.9 +0.0 4.45
5359 -1.7 3.68 3 30 00 12.18 +21.2 51.3 +21.0 +0.0 2.70
5073 -7.1 2.33 0 10 00 10.16 +17.9 42.5 +21.0 +0.0 1.76
4816 -10.0 2.00 0 10 00 10.33 +34.1 40.8 +17.0 +0.0 1.72
4591 -10.9 1.58 0 00 00 1.55 +33.1 5.6 +17.0 +0.0 1.60
4340 -11.3 1.88 0 00 00 1.57 +30.8 5.5 +17.9 +0.0 2.17
__________________
Old 08-26-2008, 06:42 PM   #15
athenG's Avatar
when logging try to log in 4th gear, cruise around 2500rpm and then floor that sucker all the way to redline. Like I said, you are only boosting around 9psi and your min/max map value is set so far apart (around 2psi). This is because your tuner used some of your load column to tune for Vacuum.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Advertise on MY350Z.COM - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
Copyright ©2002 - 2008, MY350Z.COM All Rights Reserved.
