Nissan 350Z Discussion forums, Photo Gallery and more...
Go Back   MY350Z.COM Forums > 350Z Tech Area > Engine & Drivetrain > Tuning
Sign in using an external account
Register Forgot Password?
MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Welcome to my350z.com!
Welcome to my350z.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Thread Tools Search this Thread
Old 09-11-2009, 10:37 PM   #1
BoostedProbe
Points: 2,867, Level: 32
Points: 2,867, Level: 32 Points: 2,867, Level: 32 Points: 2,867, Level: 32
Today's Activity: 0%
Today's Activity: 0% Today's Activity: 0% Today's Activity: 0%
Default Some timing input
Hey guys, I know that there are a few of you out there that are like me and want to learn as much as possible. That way when something goes (hopefully it doesn't) wrong, you know where to look. I have the Haltech platinum on my 06 350z, and I am currently running about 7.5-8psi with a turbo. I have my fuel dialed in, and it sits at about 11.5:1 throughout the entire WOT while in boost.
The timing is conservative, at peak torque it sits at about 11deg. It then start to climb to a max of 14deg at 6000rpm, and stays there to red line.
Now, what is considered "aggressive"? It is not a place where I want to be, but I am curious. I know that every car/setup is different too, and that there are other factors.
Any constructive input welcome
BoostedProbe is offline   Reply With Quote
Old 09-12-2009, 06:20 AM   #2
str8dum1
Points: 3,964, Level: 40
Points: 3,964, Level: 40 Points: 3,964, Level: 40 Points: 3,964, Level: 40
Today's Activity: 33.1%
Today's Activity: 33.1% Today's Activity: 33.1% Today's Activity: 33.1%
I'd say anything more than 17* or so would start to get aggressive and warrant a careful ear on the dyno
__________________
VQ38DETT with SFR Twin 6262 on ProEFI128 Corn Fed
str8dum1 is offline   Reply With Quote
Old 09-12-2009, 07:53 AM   #3
BoostedProbe
Quote:
I am assuming that this is the highest one would go in the critical areas (peak torque).
Don't get me wrong I am not looking at going to 17*, but rather get an idea of how conservative my tune is and how much room I have.
Old 09-15-2009, 07:48 PM   #4
Chris@FsP
Vendor - Former Vendor
The only way to find out how much room you have is to get it on a dyno, and see how much timing your motor wants. Otherwise, you're just guessing and not getting the most from your setup. Boost pressure, octane, compression ratio, etc, all play a factor into how much timing you can run before you start to knock. But if you want a number, I'd say 18-20* on a stock motor and pump gas is pretty "aggressive".
Chris@FsP is offline   Reply With Quote
Old 09-15-2009, 10:14 PM   #5
neech
So what happens when you run too little timing, besides lost power etc.. High EGR? Can very low timing values lead to preignition?
__________________
"07 Ford Mustang GT500: my s14 was faster.
neech is offline   Reply With Quote
Old 09-16-2009, 05:53 AM   #6
Chris@FsP
Yes, high EGT's and chances of detonation are increased.
Old 09-16-2009, 06:54 AM   #7
Hal@Dynosty
MY350Z.COM Sponsor
Hal@Dynosty's Avatar
dynosty dynosty
Points: 4,773, Level: 44
Points: 4,773, Level: 44 Points: 4,773, Level: 44 Points: 4,773, Level: 44
Today's Activity: 4.3%
Today's Activity: 4.3% Today's Activity: 4.3% Today's Activity: 4.3%
Send a message via AIM to Hal@Dynosty
You need to be on a dyno to tune timing. There are a no set "aggressive" values etc, as every setup is different - especially yours
Overly advanced has obvious downsides (blown motor) but overly conservative will do damage as well as rob power.
__________________
Phone: 859.230.9027. We are a performance parts distributor, with services including
dyno tuning, high performance engine building, and turn-key packages from 400-1000+whp
Like us on Facebook for shop news and sales!
Hal@Dynosty is online now   Reply With Quote
Old 09-16-2009, 08:28 AM   #8
BoostedProbe
Yeah I put a call in this morning to get the ignition timing tuned on a dyno. I am just stumped with the A/F readings at WOT, with them being off by .4a/f on average. Bank one richer than bank two.
Old 09-16-2009, 09:09 AM   #9
neech
So without getting into a full blown tuning discussion (becuase I know those are out there), in a nutshell, what do you guys look for when tuning timing on a dyno?
Do you advance until gains start to diminish, then pull back a few degrees for safety, or is that dangerous? What is the basic approach?
__________________
Old 09-16-2009, 09:23 AM   #10
Chris@FsP
On a forced induction car on pump gas, you're most likely never going to get to the point where power starts to diminish before running into knock; therefore you're knock-limited. If you are running race fuel and everything else is in place (cool intake air, proper a/f ratios) to where knock isn't going to be a problem, then yes, I would advance until the power starts to flatten out, then pull back a couple of degrees. The ultimate goal in ignition timing is achieving MBT (minumum best timing or minimum advance for best torque)
My350Z
350 Z
Paid Advertisement
Tags
blown, egt, high, minumum, timingtorque
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
ADVERTISING
INSURANCE CENTER
Advertise on MY350Z.COM - MY350Z.COM - Archive - Top
Advertise on MY350Z.COM - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Copyright ©2002 - 2008, MY350Z.COM All Rights Reserved.
Admin control Panel Backup
