Nissan 350Z Discussion forums, Photo Gallery and more...
Go Back   MY350Z.COM Forums > 350Z Tech Area > Engine & Drivetrain > Tuning
Sign in using an external account
Register Forgot Password?
MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Welcome to my350z.com!
Welcome to my350z.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Thread Tools Search this Thread
Old 10-03-2009, 03:34 PM   #1
derek173
derek173's Avatar
Points: 3,587, Level: 37
Points: 3,587, Level: 37 Points: 3,587, Level: 37 Points: 3,587, Level: 37
Today's Activity: 0.3%
Today's Activity: 0.3% Today's Activity: 0.3% Today's Activity: 0.3%
Default Cosworth Plenum on tuned ecu = problems
I had my ECU tuned with the uprev software a few months ago and everything was perfect. Yesterday I had a Cosworth Plenum installed and the car would cut power at 4500 rpm like it was hitting the rev limiter. Reinstalled the original setup and problem gone. Def was not vaccum leaks or improper install.
I am just amazed that the Cosworth makes such a big difference that the tuned ECU can't adjust for it. I figured on an N/A vehicle the tune wouldn't be so offset by a plenum change?
Expert please give opinion, I will be taking it in for a tune but I have a track day tomorrow so I had to go back to original setup.
derek173 is offline   Reply With Quote
Old 10-03-2009, 03:46 PM   #2
0jiggy0
0jiggy0 jiggy00
Points: 3,176, Level: 34
Points: 3,176, Level: 34 Points: 3,176, Level: 34 Points: 3,176, Level: 34
Today's Activity: 23.8%
Today's Activity: 23.8% Today's Activity: 23.8% Today's Activity: 23.8%
Send a message via AIM to 0jiggy0 Send a message via Yahoo to 0jiggy0
Get it tuned?
__________________
MY350Z.COM just got a little bit better with big uncle TX gone
0jiggy0 is offline   Reply With Quote
Old 10-03-2009, 04:09 PM   #3
albaugh81
Points: 1,377, Level: 20
Points: 1,377, Level: 20 Points: 1,377, Level: 20 Points: 1,377, Level: 20
Today's Activity: 0.7%
Today's Activity: 0.7% Today's Activity: 0.7% Today's Activity: 0.7%
Can I see some pics of the Cosworth Plenum now that its installed.
__________________
Nismo Cat Back, Nismo short throw, Konig Rims, Wolf Pop Charger, Motordyne 5/16, MREV
albaugh81 is offline   Reply With Quote
Old 10-03-2009, 04:25 PM   #4
gabe3d
Points: 4,313, Level: 41
Points: 4,313, Level: 41 Points: 4,313, Level: 41 Points: 4,313, Level: 41
Today's Activity: 1.1%
Today's Activity: 1.1% Today's Activity: 1.1% Today's Activity: 1.1%
I recently installed the cosworth without retuning it but did not run into this issue.
Adam@z1 ran into a very similar issue where the gasket he used not creating a good seal, but looks like you checked that already. There isn't much else to check other then the barbed fittings and plugs to see if they are on securely with some sort of sealant, even so it wouldn't create such a dramatic loss of vacuum where you could not rev past 4500. Have you checked that stupid rubber gasket they make you put on the carbonfiber caps? Or even perhaps a crack there, might be easier to see from the inside of it?
gabe3d is offline   Reply With Quote
Old 10-03-2009, 05:21 PM   #5
CeBrwn5454
Points: 2,874, Level: 32
Points: 2,874, Level: 32 Points: 2,874, Level: 32 Points: 2,874, Level: 32
Today's Activity: 1.3%
Today's Activity: 1.3% Today's Activity: 1.3% Today's Activity: 1.3%
Send a message via AIM to CeBrwn5454
Make sure you are on the right map...not a valet map. (Just making sure...)
CeBrwn5454 is offline   Reply With Quote
Old 10-03-2009, 07:15 PM   #6
derek173
derek173's Avatar
Old 10-03-2009, 07:18 PM   #7
derek173
derek173's Avatar
I will PM my tuner to see if he can double check. I think if it was a gasket problem would I not have issues at idle? So weird that it happens at upper RPM.
Old 10-03-2009, 07:19 PM   #8
derek173
derek173's Avatar
Quote:
Thanks, I did check to make sure I was on the right map. Even reset the ECU/Throttle etc.
Old 10-03-2009, 07:39 PM   #9
TreeFiddyZee
Do WHAAAAT!?
TreeFiddyZee's Avatar
Points: 2,485, Level: 30
Points: 2,485, Level: 30 Points: 2,485, Level: 30 Points: 2,485, Level: 30
Today's Activity: 0%
Today's Activity: 0% Today's Activity: 0% Today's Activity: 0%
Send a message via AIM to TreeFiddyZee
Quote:
Higher revs, more vacuum pull, so no probably wouldn't notice it until higher revs. Especially if you just have a small leak.
__________________
How do you make a small fortune in racing? Start with a large one.
TreeFiddyZee is offline   Reply With Quote
Old 10-03-2009, 08:35 PM   #10
derek173
derek173's Avatar
Quote:
Thanks, I have contacted him to double check the gaskets. So it probably doesn't have anything to do with the tune?
Old 10-03-2009, 08:58 PM   #11
gabe3d
Correct, that at higher rpms is where the problem will manifest itself.
When I assembled the cosworth I was surprised how easily the gaskets on the cap can be easily mis-aligned and susceptible to pinching. I definitely would check that before the intake manifold gasket as that one is nearly impossible to install incorrectly. The other place would be the hose connections, but that is probably not it as your tuner tried your orig parts with success. Good luck.
Old 10-03-2009, 09:56 PM   #12
derek173
derek173's Avatar
Thanks gabe, you are an awesome member of this site
Old 10-04-2009, 08:36 AM   #13
westpak
SFZCC
westpak's Avatar
Points: 10,120, Level: 67
Points: 10,120, Level: 67 Points: 10,120, Level: 67 Points: 10,120, Level: 67
Today's Activity: 2.5%
Today's Activity: 2.5% Today's Activity: 2.5% Today's Activity: 2.5%
Send a message via AIM to westpak
yes those rubber rings around the caps have to got to be the worst and biggest pita to put on and stay on, takes a lot of patience
westpak is offline   Reply With Quote
Old 10-04-2009, 01:42 PM   #14
gabe3d
Thanks for the kind works
Old 10-20-2009, 12:53 AM   #15
derek173
derek173's Avatar
A big thank you to everyone in this thread. I sent it to Cosworth after my installer found a leak following a pressure test. The manifold was sent back to Cosworth for inspection and they found it to be a bad casting and will be sending a replacement soon.
Old 10-20-2009, 09:46 PM   #16
rcdash
rcdash's Avatar
Points: 4,722, Level: 43
Points: 4,722, Level: 43 Points: 4,722, Level: 43 Points: 4,722, Level: 43
Today's Activity: 5.4%
Today's Activity: 5.4% Today's Activity: 5.4% Today's Activity: 5.4%
Too many QC failures from Cosworth.
__________________
build thread
rcdash is offline   Reply With Quote
Old 10-21-2009, 07:26 AM   #17
derek173
derek173's Avatar
Quote:
Originally Posted by Jay'Z View Post
Mega qc from Cossy......
Old 10-21-2009, 07:46 AM   #18
GreenGoblin
Points: 3,445, Level: 36
Points: 3,445, Level: 36 Points: 3,445, Level: 36 Points: 3,445, Level: 36
I had a cap crack on me, I got them to send me a replacment tho.
__________________
SFL G Club
GreenGoblin is offline   Reply With Quote
My350Z
350 Z
Paid Advertisement
Tags
350z, cosworth, crack, crosworth, ecu, g35, g37, gasket, install, intake, long, manifest, plenum, problems, spacer
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
ADVERTISING
INSURANCE CENTER
Advertise on MY350Z.COM - MY350Z.COM - Archive - Top
Advertise on MY350Z.COM - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Copyright ©2002 - 2008, MY350Z.COM All Rights Reserved.
Admin control Panel Backup
