Nissan 350Z Discussion forums, Photo Gallery and more...
Go Back   MY350Z.COM Forums > 350Z Tech Area > Engine & Drivetrain > Tuning
Sign in using an external account
Register Forgot Password?
MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Welcome to my350z.com!
Welcome to my350z.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Thread Tools Search this Thread
Old 11-07-2009, 09:02 PM   #1
RocKstR350z
Points: 1,102, Level: 18
Points: 1,102, Level: 18 Points: 1,102, Level: 18 Points: 1,102, Level: 18
Today's Activity: 0.7%
Today's Activity: 0.7% Today's Activity: 0.7% Today's Activity: 0.7%
Default Should I get a tune ??
IV been doing a little bit of research here and there but still would like some input on whick one i should get. My mods now are topspeed 3" exhuast and soon to be JWT popcharger, topspeed-y pipe, test pipes, and motordyne plenium spacer. MY question is will I benefit from a tune ?? And if so which one should i go with ?? I hope to tune it myself if possible and would like to stay under a grand
RocKstR350z is offline   Reply With Quote
Old 11-07-2009, 09:14 PM   #2
Hal@Dynosty
MY350Z.COM Sponsor
Hal@Dynosty's Avatar
dynosty dynosty
Points: 4,752, Level: 44
Points: 4,752, Level: 44 Points: 4,752, Level: 44 Points: 4,752, Level: 44
Today's Activity: 9.3%
Today's Activity: 9.3% Today's Activity: 9.3% Today's Activity: 9.3%
Send a message via AIM to Hal@Dynosty
To best answer the question it would be nice to know where you are starting from... a baseline dyno pull with AFR, or a Cipher log with afr.
The answer is yes - you will benefit. To get the most out of it would require a quick dyno tuning session... but if you prefer to do it yourself you could go the reflash route. This can work one of two ways:
1. I send you a reflash cable (osiris) with a modified map for you to upload. You load that and then make a pull while datalogging. Send that back to me, I will adjust the map if necessary and email you a new map to upload. Repeat if necessary.
2. Purchase osiris tuner and you make adjustments to the map yourself. This does not sound like the best option for you.
__________________
Phone: 859.230.9027. We are a performance parts distributor, with services including
dyno tuning, high performance engine building, and turn-key packages from 400-1000+whp
Like us on Facebook for shop news and sales!
Hal@Dynosty is online now   Reply With Quote
Old 11-07-2009, 09:18 PM   #3
RocKstR350z
Typiclly how much does number one and number two cost ???
Old 11-07-2009, 09:19 PM   #4
RocKstR350z
Also will i be able to remove the speed limitier with either number ??
Old 11-07-2009, 09:31 PM   #5
Hal@Dynosty
MY350Z.COM Sponsor
dynosty dynosty
Both can remove speed limiter, enhance the drive by wire throttle system, remove CEL codes, etc.
Option one is $499 (plus additional mapping fee if many changes are necessary depending on complexity of setup - yours should not be difficult) and option two is $699.
__________________
Old 11-07-2009, 09:41 PM   #6
RocKstR350z
So you send me a cable which i hen hook up to my laptop and my car. I open the program and itll load into my ecu. I do a dyno run while i nthe datalogging mode which i assume is on the program you send. THen you make any adjustments and i do another dyno run the same way as the first to insure that it all went well ??? Did i get that right??
Old 11-07-2009, 09:45 PM   #7
Hal@Dynosty
MY350Z.COM Sponsor
dynosty dynosty
Yes, dyno would be ideal... but most people just find a private section of road that they can make a pull to redline while logging in the program.
__________________
Old 11-07-2009, 09:47 PM   #8
RocKstR350z
I live in the country with PLENTY of roads to do that safely on everyday. Do oyu think itll need to be reodne or do you think the initial map will do just fine ?? what kind of gains are we talking here ??? NAd if battery is disconnected will it erase???
Old 11-08-2009, 07:10 AM   #9
hpro350z
hpro350z's Avatar
so are we able to switch between maps if we get 1st option
__________________
03 evo
hpro350z is offline   Reply With Quote
Old 11-08-2009, 07:20 AM   #10
BonesZ33
BonesZ33's Avatar
Points: 1,483, Level: 21
Points: 1,483, Level: 21 Points: 1,483, Level: 21 Points: 1,483, Level: 21
Today's Activity: 0%
Today's Activity: 0% Today's Activity: 0% Today's Activity: 0%
Send a message via AIM to BonesZ33
Spending 500 dollars on a tune for a N/A I/E application is a waste IMO.. save that 500 dollars and put it towards a future F/I kit.
BonesZ33 is offline   Reply With Quote
Old 11-08-2009, 12:25 PM   #11
kenpo_350Z
kenpo_350Z's Avatar
Why would it be a waste. I have a popcharger, ur underdrive crank pulley, kinetix test pipes, Motordyne 5/16" plenum spacer, and RSR ex mag exhaust. I was really thinking about a tune as well.
What difference would a person notice from getting a tune? Would it be better to get gears or some other mod than a tune?
I think 500 seems reasonable if you can really get some noticable gains.
__________________
04 Silverstone Touring ZR 6 Spd, burnt orange/black vented seats, RS*R Exmag GTII, Stillen Y-Pipe, Kinetix resonated test pipes, Motordyne 5/16 Iso Thermal Spacer, JWT Popcharger, Unorthodox Racing Underdrive Crank Pulley, JDM Clear Reflectors, S2K Antenna,30% Tint, tail light overlays, Hawk HPS pads, Kenwood DNX 7100 NAV/DVD, Seibon VS2 Carbon Hood.
kenpo_350Z is offline   Reply With Quote
Old 11-08-2009, 12:28 PM   #12
03threefiftyz
Moderator
350Z, OT, Market, Tech, Motorsports, & Mid-A
03threefiftyz's Avatar
Points: 3,897, Level: 39
Points: 3,897, Level: 39 Points: 3,897, Level: 39 Points: 3,897, Level: 39
Today's Activity: 69.0%
Today's Activity: 69.0% Today's Activity: 69.0% Today's Activity: 69.0%
It's worth it.......may only gain 5-9whp in peak gains, but there will be sizable gains under the curve and in partial throttle. Throttle response is also improved. I also still get 28-30mpg on the highway while on the performance map.
__________________
"Racing makes Heroin addiction look like a vague wish for something salty." -- Peter Egan
03threefiftyz is offline   Reply With Quote
Old 11-08-2009, 12:39 PM   #13
Z1 Performance
MY350Z.COM Sponsor
Z1 Performance's Avatar
Points: 16,404, Level: 82
Points: 16,404, Level: 82 Points: 16,404, Level: 82 Points: 16,404, Level: 82
Today's Activity: 35.9%
Today's Activity: 35.9% Today's Activity: 35.9% Today's Activity: 35.9%
Send a message via AIM to Z1 Performance
Peak gains will depend on the car, and the exact mods it has, as mentioned. My own car way back when (2003) got nice gains (12/12 as best I can recall) when I had it flashed after installing high flow cats, exhaust, and intake. When I installed the UTEC and retuned in December 2005 (no other mods done to the car), the gains went up even further. Future tunes eventually got me to roughly 40 whp over stock, with just basic bolt ons, no plenum spacer, on pump gas. I think those are nice gains, but I suppose others will disagree. It's all about perspective. Details are in my build thread in the NA section
To me, it's only a "waste" if you
1. don't care if the car may not be operating to it's peak efficiency/reliability
2. you are going to do a full balls to the wall forced induction build in the very near future (and even then, the tuning side of things is far less expensive than the hardware/software purchase, and this ecu mod will set the foundation for whatever future mods you do to the car
3. you're selling the car
everyone is always so quick to say "just get FI" but as has been said many, many times, FI is not for everyone, for a multitude of reasons. Far more people have the simple bolt ons than forced induction builds.
__________________
Adam Z1 Performance www.z1auto.com 631.863.3820 AIM:z1auto www.cornerbalance.wordpress.com
320WHP Project Z33 - All Motor - Click!
Z1 Performance is offline   Reply With Quote
Old 11-08-2009, 12:40 PM   #14
RocKstR350z
It seems to be worth it. IM not expecting my car to be doing wheel stands or anything but for the price it doesnt seem unreasondable. Any more input would be nice from people who have simple bolt ons and a tune would b e nice
Old 11-08-2009, 12:47 PM   #15
Z1 Performance
MY350Z.COM Sponsor
there are years worth of threads on it
__________________
Old 11-08-2009, 12:53 PM   #16
03threefiftyz
Moderator
__________________
Old 11-08-2009, 12:57 PM   #17
kenpo_350Z
kenpo_350Z's Avatar
I agree, it sounds like it is really worth it! Why wouldn't you want your car to run at top performance.
Z1 those are some huge gains you had. Did you do your tuning on the dyno or just using a lap top? I don't have a dyno close by and was wondering if it is worth it without taking it to a dynoe.
Also which tuning device do you guys feel is the best. The Osiris, UTEC?
__________________
Old 11-08-2009, 01:02 PM   #18
03threefiftyz
Moderator
My personal preference is Osiris.......it's cheaper as well. I also picked up ~45whp from bolt-ons/tune.
Utec might be an option for you as well though since you don't have an Osiris tuner within 300-400 miles. The e-tunes are alright, but not ideal.
__________________
Old 11-08-2009, 01:04 PM   #19
Z1 Performance
MY350Z.COM Sponsor
all my previous tuning was always done on a dyno
interestingly enough though, with all the work my car now has (roughly 100whp over stock) I've been running the past couple of months on just a quick street tune (using a wideband, and a boring timing curve). Reason being is I am still up in the air about some changes, and I'd rather just tune it one more time and be done with it. Since my current map is very very safe, and the car is happy with it, I am content leaving it as is until I figure out my next mods (if any)
__________________
Old 11-08-2009, 01:15 PM   #20
kenpo_350Z
kenpo_350Z's Avatar
Thanks for the quick responses. How does the UTEC differ from Osiris. You were talkinga bout how the etunes are not ideal. I think the closest dyno is around 3 hours for me. Not too bad if I really have to.
__________________
My350Z
350 Z
Paid Advertisement
Tags
03, 350z, basic, boltons, engine, hook, it, maps, my350z, osiris, performance, switch, tune, ways, worth
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
ADVERTISING
INSURANCE CENTER
Advertise on MY350Z.COM - MY350Z.COM - Archive - Top
Advertise on MY350Z.COM - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Copyright ©2002 - 2008, MY350Z.COM All Rights Reserved.
Admin control Panel Backup
