Nissan 350Z Discussion forums, Photo Gallery and more...
Go Back   MY350Z.COM Forums > 350Z Tech Area > Engine & Drivetrain > Tuning
Sign in using an external account
Register Forgot Password?
MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Welcome to my350z.com!
Welcome to my350z.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Thread Tools Search this Thread
Old 11-14-2009, 06:07 AM   #1
binder
Points: 3,719, Level: 38
Points: 3,719, Level: 38 Points: 3,719, Level: 38 Points: 3,719, Level: 38
Today's Activity: 8.2%
Today's Activity: 8.2% Today's Activity: 8.2% Today's Activity: 8.2%
Send a message via AIM to binder
Default Osiris CAN rewire for g35 2003?
So my osiris tuner won't flash the ROM sent to me onto my car. I saw on the website that 2003 g35 has a CAN rewire from pin 3 to pin 14. Is this the reason the flash gives me an error when i try to upload it? Everything else works fine with my cipher cable and i have no errors otherwise.
I emailed jared from uprev but it was late last night so i'm not sure if he has time on weekends to respond to emails.
Any input would be appreciated.
Oh ya, if that's not the reason for the re-wire then does anyone know what the rewire is for? It doesn't say on the website, it just has a pinout and where to move it.
binder is offline   Reply With Quote
Old 11-14-2009, 02:47 PM   #2
binder
nobody with a 2003 g35 is using Osiris? Come on, i know someone has to be using it.
Old 11-14-2009, 03:13 PM   #3
UpRevDev
For whatever reason, the 2003 G35 does not have the CAN pin in the standard location. If your connector does not have a pin in location 14, then you should do the rewire.
Cipher datalogging, etc. still works for the most part without the rewire because that uses the ISO lines, not CAN. Flashing the ECU is done over the CAN bus, so it is required for that.
UpRevDev is offline   Reply With Quote
Old 11-14-2009, 03:27 PM   #4
binder
thank you so much for that answer!
i'm really happy to hear that because I was having issues flashing. I was almost about to call it quits after a few hours of ecu resets and trying over.
Despite working a 16 hour shift and only having 4 hours to sleep tonight i'm going to head straight ot the car when i get home and wire this up!
also, once i put my license on that and upload my ROM to the car will I be able to open and view roms in the ROM editor? It won't let me view them now and it says "license error" when i try to open. I think i have to have the license on my cable first then it will let me do this.
i'm new to this software nad i've been reading the manual over and over but just have some noob questions. I'll learn this software sooner or later!
Old 11-14-2009, 06:20 PM   #5
BlinkerFluid
Points: 2,008, Level: 27
Points: 2,008, Level: 27 Points: 2,008, Level: 27 Points: 2,008, Level: 27
Today's Activity: 0%
Today's Activity: 0% Today's Activity: 0% Today's Activity: 0%
Also, you have to have your Osiris cable plugged into the computer to open the ROM files.
Another hint, in my experience, if you want to open datalogs with Cipher, and ROM's with Map Edit, open Map Edit first with the cable connected, as if you open Cipher first, it will grab the cable and Map Edit will give you the license error until you close Cipher then disconnect and reconnect the cable. Maybe this is just my computer acting silly though.
__________________
2004 Infiniti G35 TT - 20psi. 2001 Ford F250 Diesel - 28psi. 1996 Mitsu Eclipse GSX - 50psi.
BlinkerFluid is offline   Reply With Quote
Old 11-14-2009, 07:32 PM   #6
binder
thanks for the tips!
i know all software has it's own quirks but i just haven't learned this stuff yet.
So i need to keep my cable out of my car then so i can tune my rom. Interesting.
Old 11-17-2009, 02:48 PM   #7
Jeff92se
Points: 4,265, Level: 41
Points: 4,265, Level: 41 Points: 4,265, Level: 41 Points: 4,265, Level: 41
Today's Activity: 39.1%
Today's Activity: 39.1% Today's Activity: 39.1% Today's Activity: 39.1%
You have a doggy door 2003 G35 sedan with the early (aka maxima ecu) connector?
Jeff92se is offline   Reply With Quote
Old 11-17-2009, 05:17 PM   #8
binder
nope, 2003 coupe 6mt.
i changed the wire over in the connector and it flashed perfectly!
Old 11-18-2009, 08:07 AM   #9
John@z1
Z1 Motorsports
John@z1's Avatar
Points: 2,977, Level: 33
Points: 2,977, Level: 33 Points: 2,977, Level: 33 Points: 2,977, Level: 33
Today's Activity: 0.7%
Today's Activity: 0.7% Today's Activity: 0.7% Today's Activity: 0.7%
Send a message via AIM to John@z1
Awesome, you'll love it!
__________________
Email: John@Z1motorsports.com
AIM: JohnatZ1
Phone: 770-838-7777 ext 311
John@z1 is online now   Reply With Quote
Old 11-18-2009, 08:19 AM   #10
binder
ya, once i figure it out i know i probably will. Right now i'm all sorts of confused trying to learn this stuff.
My350Z
350 Z
Paid Advertisement
Tags
03, 2003, air, bus, cable, ecu, faster, fuel, g35, infiniti, makes, osiris, ratio, rewire, scangauge, tune, tuning, uprev
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
ADVERTISING
INSURANCE CENTER
Advertise on MY350Z.COM - MY350Z.COM - Archive - Top
Advertise on MY350Z.COM - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Copyright ©2002 - 2008, MY350Z.COM All Rights Reserved.
Admin control Panel Backup
