350z Wont Start, Fuse Keeps blowing
on
im new to 350z's as ive had mine for about a month. its a 05 and gots some mods. ive done some research and ive discovered the reason it wont start is because of a "Engine Accesories Fuse" in my IPDM fuse box. it worked for a little but now it keeps blowing everytime i attempt or start the car. im not sure what the problem is. im wondering what this fuse even controls it seems to do with the fuel injection but im not sure. someone please help
on
impossible to diagnose a wiring issue on the internet.
It sounds as if a wire is damaged and grounding itself out. You'll have to start going through the wiring harness to find out where the damage is and why it's grounding out thus blowing the fuse.
on
i found where a wire is slightly shorting, it was where the tachometer was spliced into another wire. i believe ignition. not sure if my HKS ignition amplifier went bad due to it, or possibly a coil? car turns over but wont start.
m_0g
06-03-2021 10:05 AM
350Z Project X
10-17-2015 05:16 PM
Beater350z
09-09-2015 03:36 PM
