Detonation Timing Map !
Old 10-02-2016, 06:20 PM
Unbootable
Unbootable's Avatar
Default Detonation Timing Map !
I have a problem with my car and would like to eliminate the knock sensor as a possible cause.
My question, Can i copy the "Timing Main" to the "Timing High Det" map ?
I have osiris standard at the moment and planning to upgrade to the tuner version if anyone confirms that it's possible.
Thank you,
Old 10-02-2016, 09:44 PM
Conway_160
Conway_160's Avatar
Wtf....you need your high det map to have less timing than your main map.
Old 10-02-2016, 11:40 PM
Unbootable
Unbootable's Avatar
I understand, And as i mentioned it's for testing only. I'm suspecting that the knock sensor is over sensitive and it's pulling a lot of timing.
Old 10-03-2016, 12:59 AM
wannabuy350z
wannabuy350z's Avatar
log and see whats your knock sum doing and actual timing advance
MartinZ (10-03-2016)
Old 10-03-2016, 02:10 AM
Unbootable
Unbootable's Avatar
Here's a log file that i did before, Green cells are exactly when the car is bogging. A typical scenario, Highway driving doing about 50 mph and give it some gas and the car will literally fall on its face.
In case you check the logs, Do you think the RPM vs ignition timing is normal (green cells) ?
Thanks,
File Type: csv
Old 10-03-2016, 03:42 AM
MartinZ
MartinZ's Avatar
You attached a CSV file which only contains the raw data - only the *.xlsx file format contains the formatting
You failed to log the knock sensor which is not very helpful when you are concerned about detonation
Looking at the data I would say you've got numerous problems and should see a tuner
The AFR is constantly in the 14.x range which is not right - it should go rich under acceleration to at least 13
It did go VERY lean (19:1) around 3,300~3,400 with no throttle - you need that fixed ASAP!!! (may not be the base map - could be no decel enrichment)
The ignition advance is a total and utter mess but there is not enough data to know if it's the base map or other factors
Old 10-03-2016, 07:25 AM
Unbootable
Unbootable's Avatar
I have always thought that knock strenth in cipher is useless !
The logging was done with partial throttle only, Nowhere near WOT, So there is no way that the AFR targets are in the 13s while you are cruising at 2000 : 3000 RPM !
I have always believed that going lean on deceleration is normal since there is a fuel cut !
That is why i wanted to try to use the main map as a high detonation map, But still i didn't get a clear answer if it's possible or no!
Old 10-03-2016, 07:32 PM
seymore4
Professional
seymore4's Avatar
Yes it is possible, you will need an unlocked copy of the tune or start from scratch tho.
Old 10-03-2016, 10:05 PM
Unbootable
Unbootable's Avatar
Noob question, Can i use the Back.To.Stock ROM or are they locked ?
Thank you,
Old 10-04-2016, 05:17 AM
seymore4
Professional
seymore4's Avatar
Back to stock roms are locked from Uprev.
Old 10-04-2016, 11:20 AM
wannabuy350z
post yourtune
Old 10-04-2016, 07:30 PM
Unbootable
Unbootable's Avatar
post yourtune
Thanks for your help,
The tune was done by Uprev as part of the three e-tunes you receive when you buy osiris.
So, Will it help if i post the ROM i received from uprev ?
Old 10-04-2016, 07:56 PM
Unbootable
Unbootable's Avatar
So how do you guys start doing your own tune if every map is locked ?, What would be my "scratch" to start from ? An ECU dump or what ?
Old 10-05-2016, 05:20 AM
seymore4
Professional
seymore4's Avatar
etunes are always locked, if you want to tune it yourself you will need to download the master rom for your ECU (you can do this through the rom editor) and start with that. You do not need to dump the ECU.
Unbootable (10-05-2016)
Old 10-05-2016, 05:42 AM
wannabuy350z
if you have the editor open and try to open the etunes
if its open post here.
and also post original rom as well
Old 10-05-2016, 09:05 AM
Unbootable
Unbootable's Avatar
Thanks guys for your support.
Here are the ROMs that i received from Uprev, Update_eTuneC.OsirisROM is the one that is currently flashed to the ECU.
I also attached the base map & back to stock one.
Hopefully someone can point me in the right direction .
File Type: zip
File Type: zip
File Type: zip
Old 10-07-2016, 06:11 AM
seymore4
Professional
seymore4's Avatar
etunes from Uprev are ALWAYS locked.
Old 10-19-2016, 11:20 AM
BluestreamDE
BluestreamDE's Avatar
My High Det map is like minus 8 degrees timing everywhere, so if I do knock severely under WOT I will definitely feel the power loss, let off an know something is wrong.
Ragheed Jamal
Engine Swaps
19
10-14-2016 01:32 PM
TreeFiddyNiSMO
10-01-2016 08:26 AM
jpernes88
South East
09-30-2016 10:58 AM
300zx32tt91
09-29-2016 10:23 AM
sjtomcat
09-28-2016 07:58 PM
Quick Reply: Detonation Timing Map !
