Nissan 350Z Discussion forums, Photo Gallery and more...
Go Back   MY350Z.COM Forums > 350Z Tech Area > Engine & Drivetrain > VQ35HR
Sign in using an external account
Register Forgot Password?
MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Welcome to my350z.com!
Welcome to my350z.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Thread Tools Search this Thread
Old 10-13-2007, 02:12 PM   #1
SeansZ
SeansZ's Avatar
Points: 3,263, Level: 35
Points: 3,263, Level: 35 Points: 3,263, Level: 35 Points: 3,263, Level: 35
Today's Activity: 0%
Today's Activity: 0% Today's Activity: 0% Today's Activity: 0%
Default Yes another oil question...
So I finally did my first oil change at 2500 miles. The oil was a nice golden color but did not look too bad. My question is, should I use conventional oil and change at every 2500 miles or should I switch over to synthetic (after I hit my 10k mark) and change every 5000 miles? Pros and cons? The cost is about the same. $40 for 12qt of conventional or $40 for 6qt of synthetic. Sure I would buy two oil filters instead of one but who cares. Any input would be great. Thanks
Sean
SeansZ is offline   Reply With Quote
Old 10-13-2007, 02:17 PM   #2
raihansdg
raihansdg's Avatar
Points: 1,741, Level: 24
Points: 1,741, Level: 24 Points: 1,741, Level: 24 Points: 1,741, Level: 24
when u hit the mark of 10k miles switch to full synthetic oil. I would recommend amsoil 0w-30. U can change it around 5000 miles.
raihansdg is offline   Reply With Quote
Old 10-13-2007, 02:55 PM   #3
Points: 9,436, Level: 65
Points: 9,436, Level: 65 Points: 9,436, Level: 65 Points: 9,436, Level: 65
Today's Activity: 99.9%
Today's Activity: 99.9% Today's Activity: 99.9% Today's Activity: 99.9%
Switch to synthetic whenever you want.
Stick with the recommended intervals in the manual.
__________________
370Z 2009 Sport Package
davidv is online now   Reply With Quote
Old 10-13-2007, 05:22 PM   #4
singh
_______________
singh's Avatar
Points: 4,236, Level: 41
Points: 4,236, Level: 41 Points: 4,236, Level: 41 Points: 4,236, Level: 41
Today's Activity: 4.3%
Today's Activity: 4.3% Today's Activity: 4.3% Today's Activity: 4.3%
Send a message via AIM to singh
^^ +1 switch whenever you want to, I switched at 1,500 miles and my car's running like a champ.
__________________
07 Magnetic Black Enthusiast 6-Speed | 20% Tint | Berk Test Pipes | AAM Competition Y-Pipe | Nismo Exhaust | Bridgestone RE-01R
singh is offline   Reply With Quote
Old 10-13-2007, 06:05 PM   #5
6894kevin
6894kevin's Avatar
Points: 2,430, Level: 29
Points: 2,430, Level: 29 Points: 2,430, Level: 29 Points: 2,430, Level: 29
Quote:
+1 but i change mine at 3k not 5k but that's just me being over protective
6894kevin is offline   Reply With Quote
Old 10-13-2007, 07:55 PM   #6
raihansdg
raihansdg's Avatar
Quote:
it takes around 8,000miles the engine breaks in, PROPERLY!!
After 8k when ur engine is broken in, then you use synthetic oil.
It not recommended before the 8k or 10k because the sythetic oil
protects the engine form wearing out (in this case its a bad thing, because the engine has to break in..DUH)
People stay till 10k, just to be safe. but hey that just me...
Old 10-13-2007, 08:15 PM   #7
SeansZ
SeansZ's Avatar
Looks like at 10k ill be going to Castrol Syntec. So what about oil filters? I prefer factory but is there a better one out there? Thanks again
Sean
Old 10-13-2007, 08:46 PM   #8
raihansdg
raihansdg's Avatar
amsoil 0w-30 is good so is castrol syntec
also http://www.my350z.com/forum/showthread.php?t=258663
for everything else
Old 10-14-2007, 06:48 AM   #9
6894kevin
6894kevin's Avatar
What ever you say man!
I changed my factory breakin oil and followed spec with breakin. I switched to amsoil and have had no problems, on my second oil change and she's spot on. In the end this has been debated over and over. So with that said do what you feel is right and enjoy the ride. I know i will!
P.S. you used duh in the wrong format=used derisively to indicate that something just stated is all too obvious or self-evident.
"this thread is a question so it's not self-evident" j/k
Cheers
Kevin
o and +1 on the amsoil again
Old 10-14-2007, 01:38 PM   #10
SeansZ
SeansZ's Avatar
As far as I no, I cant get Amsoil at the local Pepboys. Where do I go for this stuff and how much should I look at spending on a qt.?
Old 10-14-2007, 02:30 PM   #11
Q45tech
Based on the tiny miniscule size of filter and sump you would always be better off changing conventional oil AND FILTER every 90 days/3750 miles unless you are in extremely cold climates such as Alaska, Minnesota, ND etc or extremely hot climates such as lower Arizona, Texas deserts etc.
Adding a larger oil sump by a few quarts can almost double the life of conventional oil why many BMW,MB, exotics use an 8 quart sump.
Nascar mandates 24 quarts because the engine go thru a quart every 50 miles.
Q45tech is offline   Reply With Quote
Old 10-16-2007, 04:49 PM   #12
6894kevin
6894kevin's Avatar
Quote:
Two ways, look up a local dealer, or order it from the main sight online.
It's about the same price as royal purple, and well worth it
Cheers
Kevin
Old 10-16-2007, 10:04 PM   #13
SeansZ
SeansZ's Avatar
O man, I was trying to be lazy and not do the research but I guess I have to now. Haha...thanks for the info.
My350Z
350 Z
Paid Advertisement
Tags
350z, oil, qt, takes
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
ADVERTISING
INSURANCE CENTER
Advertise on MY350Z.COM - MY350Z.COM - Archive - Top
Advertise on MY350Z.COM - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Copyright ©2002 - 2008, MY350Z.COM All Rights Reserved.
Admin control Panel Backup
