You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
so just because there's not a kit out that means I'm talking crazy????? There has to be somebody out there that has made a kit for there 07. What did the DE's handle stock??
no there is no FI for the HR yet! and as far as the DE it all depends on your particular engine some more some less there is no real anwser there is alot of factors that go into it !
__________________ http://www.racemrc.comAPS EXTREME TT ON BUILT MOTOR (done by MRC Motorsports)
^^^^^I'm not talking about different types of turbos......
So out of all the turbo's on the DE's no body knows I safe psi to run???
Dude, you are missing the point. The amount of boost pressure any engine can take is gonna be relevent to the turbo that's pumping that air into the engine. All the turbo kits out there use different sized turbos, so they're all gonna differ on what a "safe" PSI is. There's no one answer.
Example - My car with the stock 16G can take 30psi no problem on the stock internals. If I try doing that with a 42R I'm gonna have problems. Same boost pressure, retardedly different cfm's.
If you can't understand that, you have bigger problems than thinking about "How much psi can a Hr motor handle???"
__________________ Team DNF - Evo IX GSR - FPBlack - 10's on pump? Let's find out...
if its safe for the DE then it would be safe for the HR(I would think anyways)
Thats pretty much saying well if a bird can fly, I would assume a dog can as well!
YOU THOUGHT WRONG!
As for safe boost, I leave you with this, take your 350Z if you own one, to a shop, say i want a custom turbo kit because I am a badass, hand them 15K and let us know.
That statement is the opposite of correct. No one knows what the HR can handle yet. Speculation was that it might be able to withstand more than the DE engine. But until someone boosts the shit out of the HR, we won't know how much it can take.
DE!...HR! two totally different ball games; for starters the HR has a higher compression ration of 10.6:1. The DE has a compression ration of 10.3:1. Both of these are different which means timing is different as well. Not to mention, lower compression is ideally better for a turbo set anyway. Which doesn't even begin to justify running higher amounts of boost.
You should also be asking yourself if the internals(mainly bottom end) is capable of running higher amounts of boost. I would venture to so NO because if you use the guy on this forum that had 13 psi on stock internals...he blew a rod strait through the piston.
Let me know if I am loosing you!
Also, to make things more complicated you have to consider because these motors are slightly different slapping on a DE turbo application to an HR is not exactly the best idea! Why? you ask: The power caused by combustion is meant to be produced in a relatively smooth manner expanding gases as a result of burning the fuel/air mixture. If you put on the wrong turbo application without proper setup and computer adjustments you will experience the wrath of Detonation and Pre-ignition. Thus, creating a giant paper weight for your garage.
I'll let you figure out the rest but if you are willing to take the risk and not wait it out then more power to you. I'm not saying it can not be done, but I think if it were up to me I would wait for companies that have been designing FI systems longer than I have been alive!
Also, to make things more complicated you have to consider because these motors are slightly different slapping on a DE turbo application to an HR is not exactly the best idea! Why? you ask: The power caused by combustion is meant to be produced in a relatively smooth expanding gases as a result of burning the fuel/air mixture. If you put on the wrong turbo application without proper setup and computer adjustments you will experience the wrath of Detonation and Pre-ignition. Thus, creating a giant paper weight for your garage.
Ummm... why are you telling me this?
