You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
ok so i was driving home from my girlfriends house tonight and i had just gotten off the tollway and was stopped at a stoplight. Well after about 2 minutes of sitting there a vibration started happening and i turned the music down to listen and it sounds like the clutch/flywheel rattle that all z's make except it was really exaggerated and almost sounded like there was no fluid. i know what it sounds like all the time but this was just a ton loud and vibrated the car a whole lot more Any ideas? Or am I just freaking out because it was loud, thanks
Does the sound go away when you press in the clutch?Sounds like Clutch throw out bearing. Do you have a lighten flywheel?Do you feel grinding when you take off?
I actually get these quite frequently. normally it is loud, but sometimes it becoemes way too loud. i hope it is normal because if not, i should be worrying too.
Yup.. Mine is really loud also. Took it to the dealer many times for this issue and had it escladed to Reginal at Nissan HQ and they also claim it is normal.
I know how you feel it's really loud and just doesn't seem right at all but Nissan claims it's norma..
When your sitting at a light for a few moments, your engine is going to get hot because there is no free flowing air entering your radiator because your not moving. Thus, the radiator fan turns on causing a slight drop in RPM's making the chattering sound and vibrations you are talking about. This also happens when you turn on the a/c from a stop. But the chattering only occurs for a few seconds and rpm's return back to normal and the chattering should go away.
__________________
Parting out full bolt on HR Z. See Mod list in profile
