Nissan 350Z Discussion forums, Photo Gallery and more...
Go Back   MY350Z.COM Forums > 350Z Tech Area > Engine & Drivetrain > VQ35HR
Sign in using an external account
Register Forgot Password?
MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Welcome to my350z.com!
Welcome to my350z.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Thread Tools Search this Thread
Old 02-28-2008, 10:36 PM   #1
Peak350
Send a message via AIM to Peak350
Default Cam Lift/Duration
I'm sure someone has measured it by now (not sure anyone will post it), but I'm wondering what the intake/exhaust lift and duration are on the HR's (factory obviously, in case that was unclear).
If anyone knows (at least the intake duration maybe?) I'd really appreciate it.
Tyler
__________________
Now drives a turbo 528i.
Peak350 is offline   Reply With Quote
Old 02-29-2008, 12:16 AM   #2
T_K
Points: 1,941, Level: 26
Points: 1,941, Level: 26 Points: 1,941, Level: 26 Points: 1,941, Level: 26
Today's Activity: 0%
Today's Activity: 0% Today's Activity: 0% Today's Activity: 0%
248 10.5, both intake and exhaust. Same as Rev-up.
TK
T_K is offline   Reply With Quote
Old 02-29-2008, 05:24 AM   #3
Peak350
Quote:
TK
Thanks a bunch.
__________________
Old 03-01-2008, 12:43 PM   #4
Q45tech
Since 1989 Nissan has used 248 durations and ~~ 9.90 -10.5mm max lift in V8 and V6.
Unfortunately the actually precise shape of the duration curve is more important than the duration.
Q45tech is offline   Reply With Quote
Old 03-01-2008, 02:09 PM   #5
Peak350
I was just doing research on plenum design and for that duration seems to be the determining factor.
__________________
Old 03-12-2008, 12:29 PM   #6
Q45tech
Unfortunately there are many simplified easy equations that can get you close but for that last 10% towards perfection you need some serious Calculus.
Knowing when the valves are fully closed is important for tuning the length of plenum runners, but has little importance in the actual calculation of grams of air [mass] flow while the valve was open.
Old 03-13-2008, 01:23 AM   #7
T_K
Just out of curiosity what do you do that you know so much technical info?
TK
Old 03-17-2008, 09:08 AM   #8
Q45tech
2 Master degrees [MSEE & MBA] plus 18 years of study in automotive engineering and 60 years of life helps.
Old 03-17-2008, 10:11 AM   #9
Peak350
Its funny because I had a professor that everyone hated (dynamics) and he hated teaching the class. His field of specialty was valvetrain design and he works with Crane Cams for developing better cam/rocker arm profiles for the LSx motors.
I went to his office one day and saw a rocker arm on his desk and instantly realized that he was one of the few professors here that had a passion for something similar to me. I am getting my degree in Civil Engineering so its a completely different field, but I had quite a few good discussions that taught me the basics of that stuff. I'm trying to learn by brail if you will....how the more complex aspects work.
If you know of any good books dealing with head flow "theory" and how the harmonics of the plenum and pre-plenum intake (and header and post header exhaust) affect the power output of a motor I'd love to read them - I just hate to spend hundreds of dollars on books that are either over my head or don't really teach something I can apply.
__________________
Old 03-18-2008, 08:11 AM   #10
Q45tech
OEM use $250,000 specialty software packages to design intakes since it is such a specialty that engineering schools don't deleve into it very much.
http://www.motortrend.com/features/newswire/91/33773/
Join SAE, there are hundreds of detailed paper presented by the experts available to purchase.
http://www.jstage.jst.go.jp/article/jsmec/47/3/873/_pdf
http://www.roushind.com/PDFs/2006/No...-GT-Airbox.pdf
http://www.mscsoftware.com/support/l...2001/lotus.pdf
Compare the miscule gains a company like Cosworth* gets after years of research over oem intakes and cylinder heads.........the Japanese are just too good to find much left on the table.
* Many Japanese oem contract with Cosworth to do their designs, so what Cosworth is doing is just tweaking their own work.
The problem with oem is that it must work at idle and cruise rpm for the average Joe.
Old 03-18-2008, 08:19 AM   #11
Peak350
Right, and OEM's have to minimize emissions with the exhaust systems while still trying to make power.
There are a lot of things left on the table as far as shifting the power band and I was more asking so I could look at the plenum stuff on my Tacoma (88 2.4L tacoma fwiw) because after seeing the HR intake I realized the complexity (square ports).
I switched plenums on my BMW (M52-M50 plenum) and lost bottom end gained top end, so I was curious how the Nissan plenum was designed in terms of power band, etc.
__________________
Old 03-20-2008, 01:29 AM   #12
J-ROZ33
J-ROZ33's Avatar
Points: 1,807, Level: 25
Points: 1,807, Level: 25 Points: 1,807, Level: 25 Points: 1,807, Level: 25
Today's Activity: 0.3%
Today's Activity: 0.3% Today's Activity: 0.3% Today's Activity: 0.3%
Send a message via AIM to J-ROZ33
kinda off topic( well not really) but does anyone know if theres cams out for the HR yet or will the cams for the DE fit the HR too?
__________________
VQ35HRFairlady Z33
J-ROZ33 is offline   Reply With Quote
Old 03-21-2008, 09:57 AM   #13
Q45tech
As to rpm tuning one need only measure [Accurately within 1/4"] the distance from the plenum box horn thru the runners to the midlift point of the intake valve.
http://www.team-integra.net/sections...?ArticleID=471
http://www.bgsoflex.com/intakeln.html
My350Z
350 Z
Paid Advertisement
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
ADVERTISING
INSURANCE CENTER
Advertise on MY350Z.COM - MY350Z.COM - Archive - Top
Advertise on MY350Z.COM - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Copyright ©2002 - 2008, MY350Z.COM All Rights Reserved.
Admin control Panel Backup
