You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
just cause its arc doesn't mean there will actually be gains
if u like the sound keep ur nismo's on, if u want the power to be more repeatable (no heat soak) then put the stock ones back on. but i can only see the heat soak being a problem if u drag race, other than that, u should be fine
__________________
no matter how awesome a car is, you can always do an el es huan swap and make it awesomer
Those numbers are from our Mustang dyno at 4500 ft altitude as well.
are there dyno's of this? is this tunable now? is someone with a pre 07 gets this and goes to a "protuner", will the tuner be able to tune this? also, is the end user tuning software (i think u guys call it "street tuner" or something like that) available yet?
when will the hr version be available?
__________________
Dyno chart:
We do not have tuning software available for these yet. I don't have a reliable date for the HR version yet. But it is being worked on.
__________________
'06 LSO Enthusiast, COBB dual exhaust, COBB intake, Prodrive GC-010G wheels, COBB Sport Springs, COBB Sway Bars, COBB Short Shifter, Porterfield Pads, Stoptech Lines, ATE Superblue fluid.
Props to Cobbs for both trying to develop products for the new HR engines and for being truthful about the stock setup being as effective as aftermarket intakes.
Just because they tested on G37, doesn't mean the Z won't get better gains. Maybe the higher displacement HR is more efficient. I know CAI don't really make much power, but I don't think this is a adequate test for both version of the HR engine.
Actually, Gambino has been awesome enough to let us do some testing on his car ('07 Z) and the results are the same. That's not to say that there isn't an intake we haven't tested that does get better results. One could exist... Maybe.
__________________
Well after that, I'll just take a cup of shut the hell up. lol
I have that stillen duel intake for about a month now I could feel the power of car from that intake and I tested so many time between stock and stillen with my gt2 that calculate 0-60second time it way faster with stillen
This is my question.+17 HP how that work,for example if I install a exhaust and from that I get 12 HP then after that ,I use stage 2
those 17 HP add to the 12 that I alredy had and would be a total of 29HP or
it would only add 5 more and bring the HP to 17.
__________________
2007 Daytona Blue ,3M clear bra,35% tint,kenwood dpx501,infinity,Fujita Air Intake,Goodrige G-stop ,Turbo XS Exhaust,Enkei RPO 3 in Kuhmo MX.Sold.370 soon.
