Nissan 350Z Discussion forums, Photo Gallery and more...
Go Back   MY350Z.COM Forums > 350Z Tech Area > Engine & Drivetrain > VQ35HR
Sign in using an external account
Register Forgot Password?
MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Welcome to my350z.com!
Welcome to my350z.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Thread Tools Search this Thread
Old 03-28-2008, 12:29 PM   #1
KCMO_HR_G
Default anyone swap out the ring and pinion gears in their Z?
If you have swapped these out, what kind did you switch to?
What size shims did you have to use?
Or did it just go right back together w/ the stock sized shims?
__________________
2008 Infiniti G35 Sport 6MT Sedan - 262whp/230wtq - 13.82 @ 102 mph - BERK HFC's FS: http://g35driver.com/forums/showthread.php?t=230718 - OEM 4.08 R&P FS: http://g35driver.com/forums/showthread.php?t=230720
KCMO_HR_G is offline   Reply With Quote
Old 03-28-2008, 01:31 PM   #2
ACEMAN
Master
ACEMAN's Avatar
Points: 10,341, Level: 67
Points: 10,341, Level: 67 Points: 10,341, Level: 67 Points: 10,341, Level: 67
Today's Activity: 0%
Today's Activity: 0% Today's Activity: 0% Today's Activity: 0%
Send a message via AIM to ACEMAN
Here you go
http://my350z.com/forum/engine-and-drivetrain/301451-4-083-gears-final-drive-installed.html
And Gooey has swapped these out on his VQ35HR engine. He went with the 4.083 and I also swapped them out and i have a VQ35DE.
Later
Todd
__________________
13.005@106.55mph Best Trap 108.54mph 03 Daytona Blue 6spd --XBOX 360 SCREEN NAME ( ACEMAN350Z )
ACEMAN is offline   Reply With Quote
Old 03-28-2008, 02:03 PM   #3
KCMO_HR_G
Thanks, I'll read through those posts.
I'm most concerned about the shim size though. I want to do this on a saturday morning with no down time... and my dealer won't stock all the shim options because they're not needed very often and would total ~$400.
So I'm trying to see how many people were able to put the nissan OEM parts into the rear end using the same shims that came in the car.
Or if new shims were needed, if there was a pattern on what size different R&P sets needed.
__________________
Old 03-28-2008, 02:27 PM   #4
ACEMAN
Master
ACEMAN's Avatar
I would talk to Adam at Z1 performance.. Great guy and knows what he is talking about.
http://www.z1auto.com/prodmore.asp?m...ne&prodid=2833
He can let you know which install kit would be right for you.. You should replace the bearings while your in there aswell.
Todd
__________________
Old 03-28-2008, 03:32 PM   #5
KCMO_HR_G
Todd
yea... this is from their website:
"Please note that in addition to the parts shown, there are also several sizes of side lash adjustment shims that Nissan offers. There is no way for us to determine what size(s) your car might need. The ONLY way to determine the proper size lash adjusters is during the installation by a competant installer. For those with higher mileage cars (typically over 25k miles) or who want additional peace of mind during the install, we also can offer the bearings as well as the bolts used internally."
My car only has 6,500 miles on it, so the bearings should be fine... I just wanted to get a sneak peak at what I'd be looking at shim-wise when I got it opened up.
I've heard from various other installers that worked on domestic cars that if the tolerances are tight on the gears, the same shims should work. So if i'm going with the OEM 4.083 R&P, I should be able to directly swap it.
Just wondering if this is how it has worked for other Z/G owners.
__________________
My350Z
350 Z
Paid Advertisement
Tags
32, 350z, 408, differential, g35, gears, infiniti, infinity, install, options, pinion, ring, stock, swap
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
ADVERTISING
INSURANCE CENTER
Advertise on MY350Z.COM - MY350Z.COM - Archive - Top
Advertise on MY350Z.COM - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Copyright ©2002 - 2008, MY350Z.COM All Rights Reserved.
Admin control Panel Backup
