HR swap into an 03
Old 07-19-2008, 09:46 AM
Lightning Guy
Lightning Guy's Avatar
Default HR swap into an 03
I just picked up an HR long block and am planning on doing a swap this winter but I have a couple of questions:
does anyone know if the fuel injectors and fuel rail froma DE will work on an HR?
I know the HR has a new accesory drive setup, do you think the old accesories would work? Just the basics, alternator and power steeriing. I don't have AC.
Can any one cross reference the cam position sensors to se if they are the same?
I have an exra DE motor in the garage and I'm doing the HR swap for mostly track purposes, I'de like to keep it as cheap as I can.
Anyone have prices on OE plenum, lower intake, TBs, engine harness?
Old 07-19-2008, 10:35 AM
Rogue350z
!!HR TT!!
Rogue350z's Avatar
Wow big project. Don't think this will be easy...
Old 07-19-2008, 10:41 AM
Cux350z
hatersgonnahate
Cux350z's Avatar
i thought you were getting a new motor from nissan?
Old 07-19-2008, 01:12 PM
Lightning Guy
I like a challenge. You still coming up in August?
Old 07-19-2008, 01:13 PM
Lightning Guy
You, already got it and in the process of breaking it in. If the HR swap doesn't work, then I still have a great low milage DE running. If the swap does work I think there is more potential inthe HR motor long therm.
Old 07-19-2008, 02:00 PM
Sergio07350Z
Sergio07350Z's Avatar
subscribing
Old 07-19-2008, 02:05 PM
Hraesvelg
Got Uranium?
Hraesvelg's Avatar
Swap the G37 engine... or better yet the GTR engine. j/k
Looking forward to pics.
Old 07-19-2008, 03:22 PM
Lightning Guy
What part of keeping it on the cheap didn't you get? LOL
I picked up an HR long block for $350, long story but there was a really nasty pushy customer at a dealership and under duress they replaced the motor for an relatively minor issue.
My goal: #325-350 WHP in my 03 and getting the car ~2800# wet. THe car's weight is getting close and what a sweet deal on the long block.
My ideas:
Xerd headers, DE lower intake manifild, rev-up lower plenum, Modified Crawford upper plenum with Dual 68mm TBs, HKS FCon to tune. I think I could probably keep the 03 fuel system, assuming the DE Fuel rail will work and I don't have to replumb the whole car (don't really see why I would). I am not worried about heat or AC, functioning (I don't have it now). Will probably need some cams to handle all of that air. I might even be able to keep the 03 hood with the Crawford plenum, will have to wait and see. I've heard the HR block sits lower (got that from NNA), so I don't know why the goofy hood unless it is for the plenum cover (thank gawd they covered the plenum).
I think I can hit the #325+ WHP cheaper and easier with the HR motor rather than the DE motor, plus I love the RPMs.
For those tht don't know, I do a lot of Road course driving, I don't want turbos and I don't need massive HP, I think 325-350 with the drivetrain in the car is plenty, for now.
Old 07-19-2008, 11:43 PM
fstrnldr
fstrnldr's Avatar
Fuel Rails are different for sure.
As far as the accessories, front cover has changed, so i doubt the old accessories will be a straight bolt on, although i haven't tried it to verify just how much works and doesn't work.
Crank pick up changes location, but i don't know if the sensor itself changed.
i'm too tired right now to try and remember all the changes off the top of my head, but basically the engine looks really close to the same, its just not close enough to be easy.
Old 07-20-2008, 05:33 AM
Lightning Guy
Thank you for the info. I don't actually get my hands on my HR until Labor day weekend, so I looking for insight as to what I actually got my self into.
Old 07-20-2008, 07:01 AM
Rogue350z
!!HR TT!!
Rogue350z's Avatar
Yeah. Should be a good time.
J
Old 07-20-2008, 07:05 AM
Rogue350z
!!HR TT!!
Rogue350z's Avatar
Some pics of my HR...
Attached Thumbnails HR swap into an 03-motor_04.jpg   HR swap into an 03-motor_03.jpg   HR swap into an 03-motor_06.jpg   HR swap into an 03-motor_10.jpg   HR swap into an 03-motor_11.jpg
Old 07-20-2008, 10:50 AM
NISMO_558
NISMO_558's Avatar
My ideas:
do DE plenums even work on the HR's?
Old 07-20-2008, 11:41 AM
SOLO-350Z
'12 TL SH-AWD
SOLO-350Z's Avatar
DE plenums do not work on the HR
Old 07-20-2008, 11:51 AM
pmohr
pmohr's Avatar
Fuel injectors from the DE will work in the HR, even with the rails being different.
Just an FYI.
Old 07-20-2008, 04:05 PM
NISMO_558
NISMO_558's Avatar
thats what I thought, but the OP seems to think so. And how the hell is someone suppose to modify a crawford plenum to a dual intake? I don't think he realizes the crawford plenum actually replaces both the top and bottom plenums.
Old 07-20-2008, 04:20 PM
Jarred@Z1
Z1 Motorsports
Jarred@Z1's Avatar
sounds like the start of a big project that could easily become a big mess.
Old 07-20-2008, 06:23 PM
Lightning Guy
Not even with a DE lower intake manifold?
Old 07-20-2008, 06:24 PM
Lightning Guy
J
Can't wait
Old 07-20-2008, 06:28 PM
Lightning Guy
Jeremy, thanks for the pics, I won't pick up the HR until labor day. Nice to see one out of the box. Looks like the HR plenum does the same thing as the DE, starves the front two cylinders. Looks like the water is completely different too.
Quick Reply: HR swap into an 03
