HR - Aftermarket Clutch & Flywheel
Old 11-16-2016, 12:16 PM
  #301
travlee
Master
travlee's Avatar
Received 9,047 Likes on 6,513 Posts
Originally Posted by PP08HR
Hey Guys,
Just installed JWT clutch and flywheel, HD CSC, and HD master.
All back together and it doesn't seem that the clutch is disengaging...
Any ideas?
might need to adjust the rod behind the master. if you got the one from zspeed, call Joe and he will tell you how to adjust it
PP08HR (11-19-2016)
Old 11-16-2016, 02:50 PM
  #302
PP08HR
PP08HR's Avatar
My tech said he adjusted to rod all the way out and still nothing... Do you think maybe the pedal might be adjusted?
Old 11-16-2016, 03:26 PM
  #303
Italianjoe1
Italianjoe1's Avatar
Did he install the spacer for the CSC? Sure there's not still air in the system?
Old 11-16-2016, 03:29 PM
  #304
Staisman
Staisman's Avatar
Do you have RJM pedal installed? if so you have to put it back to stock position to properly bleed the clutch.
Old 11-17-2016, 06:01 AM
  #305
ZSpeedPerformance
Vendor - Former Vendor
ZSpeedPerformance's Avatar
Adjusting "all the way out" is not the proper way to do it, This can cause you to kill your clutch very quickly if not done correctly.
I have sent you the PDF download of the clutch adjustment procedure as requested in your e-mail.
PP08HR (11-19-2016)
Old 11-17-2016, 06:06 AM
  #306
travlee
Master
travlee's Avatar
joe to the rescue again
Old 03-10-2017, 05:23 AM
  #307
GodISmE
GodISmE's Avatar
Which combo do you guys recommend for 08 HR track car with OS Giken 1.5 and 3.9 FD?
I should probably not go for THE lightest flywheel available or should I?
Also, my clutch pedal does not go back to the top position as quickly and strongly as it used to. Might this be a sign of the CVC going? Do I buy it seperatly or does it already come with aftermarket clutches?
Old 03-10-2017, 05:28 AM
  #308
ZSpeedPerformance
Whats the power level?
Old 03-10-2017, 05:45 AM
  #309
GodISmE
GodISmE's Avatar
NA built, Up to 330hp for now and maybe over 350hp next year with cams and 3.7l.
Old 03-10-2017, 05:58 AM
  #310
ZSpeedPerformance
ZSpeed Stage 2 +
These are very durable kits for track, Will have some trans gear rattle at idle and low rpm as any kit with solid flywheel and non-quiet type clutch but will take whatever you can throw at it. Triple strapped plate design, SFI Certified disk and pressure plate, we use a non marcel racing organic disk with these for long life, Very clean clutch release for fast shifts and very manageable.
Clutch + Cmak
http://www.zspeedperformance.com/ZSP...SPSTG2-SFI.htm
Clutch + CMAK + Flywheel, I would recommend the 17 or 19lb flywheel.
http://www.zspeedperformance.com/ZSP...STG2SFIFly.htm
Old 03-10-2017, 06:58 AM
  #311
GodISmE
GodISmE's Avatar
Isn't 17lbs a bit heavy for a track car? I was thinking about something closer to 14lbs.
Old 03-10-2017, 07:23 AM
  #312
ZSpeedPerformance
Well the only way you can get that light is an aluminum inserted flywheel that will eventually have parts come off of it and most likely a warped insert after some heat. I would highly not recommend that for a track car. 3lbs in exchange for durability is worth it to me, just a few less cheeseburgers...
NA&CH (04-03-2017)
Old 03-10-2017, 03:03 PM
  #313
Surfer90291
Surfer90291's Avatar
I remember reading on the motorsports section that the VQ likes momentum and a lighter flywheel won't make you faster on a timed lap.
I installed a JWT and CMAK and the latter works flawlessly, the JWT is aluminum so I hope it won't separate. I love how faster it revs now.
Old 03-11-2017, 11:04 AM
  #314
Frostydc4
Frostydc4's Avatar
Originally Posted by ZSpeedPerformance
ZSpeed Stage 2 +
These are very durable kits for track, Will have some trans gear rattle at idle and low rpm as any kit with solid flywheel and non-quiet type clutch but will take whatever you can throw at it. Triple strapped plate design, SFI Certified disk and pressure plate, we use a non marcel ACT steel backed organic disk with these for long life, Very clean clutch release for fast shifts and very manageable.
Clutch + Cmak
Is the CMAK mod reversible?
Old 03-11-2017, 11:18 AM
  #315
ZSpeedPerformance
Absolutely, you do not modify anything on the car to install it. Just a bolt on kit.
Old 03-11-2017, 12:42 PM
  #316
Frostydc4
Frostydc4's Avatar
How does the JWT flywheel compare to the 17lb listed on your site & can the JWT LTFW be mated with the clutch/CMAK setup you are selling?
***Disclaimer: car is not my daily driver***
Old 03-13-2017, 03:57 AM
  #317
GodISmE
GodISmE's Avatar
Isn't the JWT flywheel made of aluminum?
Old 03-13-2017, 06:18 AM
  #318
ZSpeedPerformance
Steel will always be more durable than aluminum,
Yes the JWT fly will work fine with the CMAK and any of our clutches.
Old 03-13-2017, 06:59 AM
  #319
GodISmE
GodISmE's Avatar
Do you sell the 17lb flywheels seperately?
Old 03-13-2017, 07:20 AM
  #320
ZSpeedPerformance
Yes, We are in process of building new site, If you would like to order just email or call.
Quick Reply: HR - Aftermarket Clutch & Flywheel
