You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
i just ordered a stage 2 spec cluch kit, cluchmaster aluminum flyweel, invidia test pipe, and aem dual cold air intake. anyone see any problems with anything here? first time z owner and trying to get as much info as i can form people that know.
how do you fig that? the test pipe in general was a question mark i have read about hesitation problem on a stock system. and what goal are you talking about ?
2nd opinion:
Waste of money as well. The test-pipes and intake shouldn't have been bought. They just add noise and reduce low-end torque and screw up your power curve. Suspension and rims would be the ideal first 2 choices for this car. Sound system and tint would have been better choices as well. You want performance, turbo(s) or supercharger should be looked into. Basic engine bolt-ons won't cut it with this car.
this is tru but i also live on longisland and was planing on geting a tune and after reading about phenoms tuner on longisland i think that will help with the curve, that or just get a cobb port
what do you want for your car...go or show...both?
This is what I'm mainly talking about cause you can setup yourself up better in spending your money more wisely...
since this is your first Z car...let me be the first to tell you with this car getting power is like squeezing water out of a rock...
so read up...N/A or Force induce both are good paths once done right...
2nd opinion:
*scratches head*
__________________
MY350Z.COM just got a little bit better with big uncle TX gone
o ok i see where your going, yea had owned a mazda rx8 befor this and it was the same way with that rotory what a pain to get anything more out of it. but im looking for go not so much show but for right now i cant be blowing over 5gs on a turbo thats the ideal for me to do i know.
OK I found the clutch. Definately a step up from the OEM clutch. Torque capacity rated at 525 pounds. Looks good for drag racing. Not too much fun on the street for a naturally aspirated 350Z.
OK I found the clutch. Definately a step up from the OEM clutch. Torque capacity rated at 525 pounds. Looks good for drag racing. Not too much fun on the street for a naturally aspirated 350Z.[/quote]
i dont think that was the stage 2 kits when i read up on the clutch it was only a 390 torque capacity and the street drivability was good for everyday little stifer but not by much
. It doesn't seem like you know much about or have much experience with bolt-ons on a 350z.
Hey dude use your brain before you post. There are penty people who make 300rwhp and up with bolt ons. Maybe for you suspension and wheels and sounds and tint would be the first step. Others prefer go before show.
i dont think that was the stage 2 kits when i read up on the clutch it was only a 390 torque capacity and the street drivability was good for everyday little stifer but not by much[/quote]
OK cool. Sounds like a good match for the flywheel.
OP - that clutch is going to be nasty for the street. Unless your stock clutch is toast, why are you changing it out of curiosity?
2. Invidia doesn't make test pipes for the 2007 + 350Z as far as I am aware..only 2003-2006. 2007 + are completely different and will not fit
3. intake - works fine
4. probably should have researched this stuff before you purchased, but if you need help going forward, we're 15 minutes away from you, and know the cars backwards and forwards
yea seemed like a good was to free up some rwhp with the lighter flyweel and being that i got the car used with 9000 mi on it and one week i had it i brought it in to a nissan deeler just to see if all was fine and they told me i needed a clutch so anythings better then that
