Stillen Generation 3 long tube intake for VQHR
on
Stillen Generation 3 long tube intake for HR
I was just browsing Stillen's website today when I noticed that after I put my '08 350z in the car selection drop down it came up with the available Generation 3 long tube intake. I didn't think the Gen 3 long tubes worked on our cars, but the site suggests otherwise. They even have a dyno which shows 20WHP gain, and they have a pdf showing installation.
Dyno: http://www.stillen.com/product_files/402845~dyno.pdf
Install: http://www.stillen.com/product_files/402845~inst.pdf
Notes on the page say "installation requires mild enlarging of core support" and that it "DOES Fit NISMO 350Z". Also "(Oil or Trans Cooler Req Custom Mod)". You will see this when you go to the page http://www.stillen.com/product.asp?id=STIDHIFLW03&c=PE and then select your car.
10/26/2009 Update: I just installed these intakes, go to fifth posting on page 3 in this thread to see my results!
on
Well, I tend to believe it is possible to make an intake produce more hp gains than the injens. I just talked to Stillen tonight and I think before anyone says anything we should give it a chance. Supposedly the dyno on the 350 HR was without a tune, and did show the most gains out of the three (g35, g37, and 370z). Who knows until it is independantly tried and tested. It is possible, and if it produces more hp than the Injens I for one am interested and all for it! :-).
Vendor - Former Vendor
This is a brand new release for the DTB 350Z's, and I think our reputation on the Gen 3 Intake System speaks for itself on the other applications.
We look forward to an independent dyno.. as our dyno is always suspect.. but we get that, unfortunately there are others in the industry who do like to play with their in-house dyno numbers.
The composite core support just needs to be slightly enlarged to accomodate the intake tube passing through it. It's a minor trimming, and can be done in a variety of ways. I've seen anything from dremels to sonicrafter's.. anything to make trimming easy.
While this customer really oversized the holes necessary for the install on this Gen 3, here's a youtube of the entire install so you can get a feel for the process.
http://www.youtube.com/watch?v=eWKgTZoAyNQ
on
Thanks for the video Josh! I talked to Andrew at Stillen and am waiting a call back from him regarding my next question, but thought it might be useful to ask this question on here as well for others to see: What are the additional modifications that need to be performed on the Nismo edition as mentioned on the Stillen website?
Checking on the specific differences in the Nismo 350Z.. the main reason we noted it is the Gen 3 for the Nismo 370Z will not fit, while the Nismo 350Z does.. As you know there are some differences in the front, not to mention the additional support bracing, etc.
Yes, we do use K&N filters for the intakes, and are specific to each kit.
Confirmed there is no difference on the installation into a Nismo 350Z, the only reason it's stated is because there can be some differences, such as the 370Z.
However an oil and/or transmission cooler will take some adjustments to all work together, but won't work with our bolt-in kits as is, just require some modifications.
on
on
Ok, I am excited to say I just ordered the Gen 3 intakes, and also the 409 headers. I will hopefully be getting them both installed within a couple weeks and will also do before and after dynos (on the same day if I can). Wish me luck and I will be keeping you guys posted on the results. I also have Crawford HFC and Fast Intentions Intimidator exhaust already installed (and love them!). After the headers and intake are installed I will probably get an uprev tune in the very near future and be done for a (hopefully long) while (until the SC). ...famous last words.
Z1 Motorsports
Z1 Motorsports
on
