You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I recently bought test pipes for my HR and I have heard that I should not utilize the mounts because of cracks on the welds in the long run. Any truth to this?
Here's the direct quote from the website I bought them from.
"These test pipes have mounting brackets just like stock but we suggest not using the brackets. The brackets cause the exhaust system to become to ridged and over time this will lead to cracking at the weld between the bracket and the race pipe."
__________________ 08' Nismo #1565 -R.I.P. You will be missed
testpipes are FTL. you should only be using testpipes if your going to be testing them for dyno or track use man. other than that its just gonna make your engine run RICH and overtime ruin the cylinder walls ! sell them save up some cash. get some HFC
What?
You don't really believe that, do you?
__________________
Old car: 06 Cobalt SS ..... New car: 08 Nismo, #1456
Proof needed.
__________________ Through fiction we saw the birth of futures yet to come. |INGS+1|Fujita|Seibon|Tommy Kaira|Tanabe|Altered Atmosphere| NISMO|Nardi|Alpine|MTX|
idk i had tps for about 4k miles until today i swapped them out for hfc's to pass emissions in north carolina but mine didnt have brackets and i didnt have a single problem with them nor did i experience any check engine lights. like always stated with tp's there will be a smell but its not that big of a deal
wha wha what?
as far as a DIY....really nothing to it. Go under the car and look at the stock cats, and you'll see if you feel like doing it yourself. Not hard at all, but you need proper extensions, etc. If they are halfway decent, they will be a direct swap. The fact that they have brackets that they tell you not to use is lame...because those brackets are now going to knock against the chassis of the car without being bolted to it.
After raising the car on a lift, I was baffled on how to get the top bolt on the left (if your facing the car) cat off. I used a swivel on a 24inch extension and still couldn't get it without slipping off the nut...no homo.
