You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
A stroker adds more wear and tear. Pistons speeds are higher! We race stroked motors in the APBA and IJSBA aka jet ski racing and engines need to be torn down and rebuilt more often due to the wear on the two and four stroke engines.
The Torque is amazing! But do you have the cash to rebuild it if compression drops or a bearing fails?
__________________ Nismo #575 Redline Crawford HFC's~UpRev~CE28N Time Attacks~MCR~Quaife~4.08FD~Samco~SPL~HKS Hypermax III's~HKS Hi power True Dual~Stillen headers~Rays long red Lugs~S2K Antenna mast~Injen CAI's~Toyo TR1's~15% Tint~AMSOIL
If a bearing fails or compression drops on any motor, you run into the same problem
Piston speed will depend on the stroke of the crank, and the rpm range of the engine - faster piston speeds are not a given by any means. Typically strokers have a lower rpm range than non strokers
A well built motor will be able to cope with this better than a stock engine can, as the quality of the components can be better (and lighter in many cases), as well as the tolerences of the bearings. The success or failure is in the quality of the components and the skill level of the machinist
Going from 3.5L to 3.8L with all stroke will increase max piston speed about 8% and max acceleration 9% using the same length rods. Those numbers go down if you increase rod length on the stroker.
There is a twin turbo 3.8 hr being built right now. GTM is doing the build for me. Don't want to say to much to soon but it is happening now. There will be a thread keeping track of the build soon.
