Nissan 350Z Discussion forums, Photo Gallery and more...
Go Back   MY350Z.COM Forums > 350Z Tech Area > Engine & Drivetrain > VQ35HR
Sign in using an external account
Register Forgot Password?
MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Welcome to my350z.com!
Welcome to my350z.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Thread Tools Search this Thread
Old 10-30-2009, 11:08 AM   #1
Peak350
Send a message via AIM to Peak350
Default Crankshaft Position Sensor / Flywheel Issue
Bold below is my question, if you don't want the backstory.
I replaced my clutch and flywheel (the Jim wolf stuff I had was crap, more on that later) for a used Stock flywheel from a junkyard and a new factory clutch I bought from Kyle@IPP.
I cleaned the flywheel surface thoroughly, as it had rusted sitting in the elements, and scuffed the pressure plate. The components all went in fine, got the car back together and it won't start.
My tach doesn't show RPM during cranking, which makes me think its a crank position sensor signal issue. I pulled the crank position sensor (its top right side of the tranny at the bell housing, remove from the bottom, 10 mm deep socket and a short 3/8" ratchet worked for me). The timing ring on the flywheel is rusty, I sanded most of the teeth themselves clean through the access area on the bottom of the engine, but still don't get any signal at all (meaning no spark...).
Could the rusty timing ring cause the "Hall IC" sensor to work improperly? If so I'll pull it apart and clean the ring up...just hate to pull the entire trans out AGAIN if that isn't the cause.
The Jim wolf stuff being crap = ring gear got chewed up by my starter and would grind often on attempts to crank. The clutch was the DE clutch that JWT said would work, it blew a slave cylinder and is clearly not the correct pressure plate at all, the teeth aren't long enough. I feel duped
__________________
Now drives a turbo 528i.
Peak350 is offline   Reply With Quote
Old 10-30-2009, 11:34 AM   #2
Peak350
It appears my buddy and I missed the alignment dowel on the flywheel, its possible I got it on wrong, taking things apart now...
__________________
Old 11-02-2009, 03:51 PM   #3
Peak350
The flywheel was off 180 degrees....doh.
Car runs fine now.
For reference, take the crank position sensor out just to be safe.
__________________
Old 11-03-2009, 09:04 AM   #4
musubi
musubi's Avatar
Points: 1,501, Level: 22
Points: 1,501, Level: 22 Points: 1,501, Level: 22 Points: 1,501, Level: 22
Today's Activity: 2.8%
Today's Activity: 2.8% Today's Activity: 2.8% Today's Activity: 2.8%
Wow, glad everything worked out for you. Sucks to hear about the JWT setup. Maybe that's why certain individuals who've switched over to it had their CSC give out? I'm guessing your initial stock flywheel and clutch both were burned out and unable to reuse the flywheel? Those flywheels are stupid expensive.
__________________
08 350Z Nismo #833 , 91 Toyota Pickup
musubi is offline   Reply With Quote
Old 11-03-2009, 02:48 PM   #5
Peak350
Quote:
The stock flywheel broke, in limping the car home (or maybe just the drag racing from before) the clutch disc was worn. I think it was mostly getting home, it was full slip for 25+ miles of driving and it was already hot when I left the track. I got a junkyard flywheel for $100 with a used clutch (in good shape, but rusty pressure plate). Bought a new clutch system just in case, about $600 in those parts total.
My slave has 3,500 miles on it I think (officially) so I was one of those who had it fail, the JWT's stiffness plays a role in the failure, a large role, as does heat. The external conversion is the way to go completely.
__________________
My350Z
350 Z
Paid Advertisement
Tags
350z, aligned, crank, crankcase, crankshaft, engine, flywheel, g35, improperly, jwt, nissan, position, positioning, restore, rusty, sensor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
ADVERTISING
INSURANCE CENTER
Advertise on MY350Z.COM - MY350Z.COM - Archive - Top
Advertise on MY350Z.COM - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Copyright ©2002 - 2008, MY350Z.COM All Rights Reserved.
Admin control Panel Backup
