HR with Tomei cams 272's 10.8 Lift
I just wanted to share my setup with what i have going on. I just recently put in some Tomei cams. 272's with a 10.8 lift, also tomei valve springs, tomei retainers with a nismo oil pump. Nick at 5523 motorsports did the install and did a great job I have to say. This is first start up at the shop. hope you guys injoy. i have more videos. Getting tuned Jan 12. hopefully have some numbers for you guys.
abarclay (01-09-2016)
here is another video pre tuned just getting the data logs in and getting help with setting the a/f just right for taking it to the dyno. cams pull hard as hell compared to stock.... not to mention it no longer wants to fall on its face after 65-6800 rpm. it pulls all the way past redline.
i did a write up in the nismo section... its #0323 on top of the posts. dyno tune is this tuesday for me to post up numbers to see how they do. this is just a project to see how they do on stock compression. i have no clue what the outcome of this will be. i have a full tank of 100 octane in the car ready for next weeks tune. i have always wondered how this setup will do. but i can tell you for 91 octane rough tune with a little bit rich across the power band to be safe so i can drive it to the dyno, it pulls way harder than stock haha. all the way to redline. i can now safely rev it to 8500 rpm only if need be. it all depends on where the power peaks and i have the nismo oil pump so it doesnt fail banging between gears at higher rpms....
The following 3 users liked this post by T-dizee:
I want this so bad
