Low oil pressure at idle???
Just did mine on my 07 Nismo. No check engine or p codes. Gasket is made of paper and it blew. I included the parts list for all the gaskets.
https://my350z.com/forum/maintenance...iast-151k.html
Took it apart without taking the front end off...putting it together with the front end off was SO much faster lol.
Best advice for anyone doing this is rip that front end off first!
rancor (01-27-2017)
Eps gaskets have metal.inside? I just dont feel like doing it again in case t hey will blow and leak again
I know this threads old but I came across it when searching and my oil pressure is like 10 psi at idle... Normal/spec at other rpm ranges, no oil pressure light at idle, no code, no noise, just under 50k miles, running gtr oil (Mobil 1 0w40.) my shop foreman at the Nissan dealership said this happens on the 4.0 L motors too. He also said that the spec used to be 6-8 psi at idle and as long as its operating normal, not making noise (lifter from lack of oil etc) and there's no code then not to worry about it until it becomes bad enough to actually cause a problem... But in my case I can do this at anytime so I'm just gonna wait. He also said these cars rarely come in for this because only **** people like us even notice this and he has not seen it cause a problem yet... He's a master tech that's even gtr certified.
Note: my oil pressure is only showing that low on the gauge in the car and I have not put on a manual gauge yet or looked it up on consult. The pressure is also only this low after heavy driving when the oil gets really hot and thin. My engine runs like a top and makes no strange noises.
the tell sign of the oil gaskets blown out are low oil pressure at idle.
This was my only problem, I Replaced the gaskets and now i idle about 28PSI at warm idle.
I Was at around 8psi warm idle before.
i would NOT drive around with your oil pressure that low at idle, It will only get worse. I Parked my car until i was able to fix it AS SOON as i noticed a problem.
Anything below 14PSI warm idle IS a problem. Fix it if your that low.
changing oil viscocitys will not fix the problem, Your oil gaskets are blown out if your seeing pressure that low at warm idle. Oil pressure is not something to "just ignore and pretend its not a problem"
again, Anything under 14PSI @ warm idle = problem. Fix asap.
Yes i know the gaskets are blown however this will not result in any problems. Nissan minimum spec at idle is 14 psi. Oil pressure is normal during driving. So please enlighten us all on how this will cause an issue. Nissan wont touch my under warranty car because its in spec and no oil light. Id love for you to give me info to tell them to make em replace my gaskets under warranty
Read many many many stories about people ignoring these gaskets resulting in massive pressure loss blowing engines.
Oil pressure is pretty important, These gaskets are thin *** paper that are already breaking up in your motor, They will get worse in a few months absolutely.
There is a reason the min warm idle spec is 14 in the FSM
anything below that indicates a problem that needs addressing
I'm not arguing that my gaskets are blown... I'm saying my idle is not low enough to hurt my motor. It's good to fix things before it's actually necessary but in my situation I can do it any day after work, so I'm gonna wait until it's an actual problem. My idle may be at 11 psi but my motor does not have any ticking, any oil pressure light, my oil pressure is 43 psi at 2k rpms and 59 psi at 3k rpms. It's also an option to just raise my idle with consult III +, just saying.
Im also experiencing this issue, recently, the past two days, my oil light will sometimes pop on at idle. Previous trial and error has lead me to believe that it was just an inaccurate gauge, but now I'm beginning to think otherwise.
My operating oil PSI's are close, besides idle, my gauge "wanders" so much its hard to get a consistent reading, sometimes the gauge reads perfect at "hot" temps (after 15-20min of driving) and sometimes its about ~5-8psi off the stock spec of >14 at idle and >45 at 2000RPM.
Two things, however, I am getting to the point of an oil change, ~7,000mi since last with RP 10w-30, which I've been told to switch to a 0W-40, and I also am about a little less than a quart low, could these issues be lending to my oil light popping on from time to time, 3x total in last 2 days, or is it the dreaded "oil galley" gasket?
Gonna revive the old thread.
Some time ago I've noticed drop in oil pressure before changing oil (was 5w50 Miller's Oil) to new 5w50 Miller's Oil. It was 30psi at warm idle and 60psi at 2000rpm warm. Now it's about 20psi at warm idle and little over 45psi at 2000rpm warm. It's '06 revup. Do I need to panic now?
#38
