HR clutch height adjustment
Old 07-29-2016, 08:01 PM
Sheasta
Sheasta's Avatar
Default HR clutch height adjustment
Hello everyone,
I adjusted the clutch height to where I wanted it and came out the next morning to my clutch stuck engaged.... Which brought me to this thread
https://my350z.com/forum/engine-and-drivetrain/582562-clutch-pedal-issue-after-adjustment.html
If you read a few posts down you see RJM performance explain how the clutch assist spring puts continuous pressure on the master cylinder which can cause problems.
I raised my clutch a bit to drive to work today and after work it was lower again (not stuck engaged, but lower.)
Has anyone tried removing the clutch assist spring on HR ? I keep finding stuff about the older generations. Any other solutions besides $300 on an aftermarket clutch pedal? That seems excessive to me.
Old 07-30-2016, 08:46 AM
dcains
dcains's Avatar
Spring for the RJM pedal (pun intended), and you'll be very happy. I've been driving only manual transmission cars for 42+ years, and the RJM pedal transformed the clutch on my Z to something I really enjoy. Well worth the $249. Get one quick, as this is the last batch that's going to be made.
Old 07-30-2016, 11:57 AM
travlee
Master
travlee's Avatar
Received 9,047 Likes on 6,513 Posts
Your slave took a dump on you
Old 07-30-2016, 12:44 PM
dcains
dcains's Avatar
Not necessarily. I think the clutch pedal is misadjusted.
Old 07-30-2016, 12:56 PM
travlee
Master
travlee's Avatar
Possible, but if its never been touched i doubt it. We shall see in time... his symptoms mimicked mine exactly
Old 07-30-2016, 12:57 PM
travlee
Master
travlee's Avatar
Edit.. reread everything and yeah its possible is misadjusted
Old 07-31-2016, 05:14 AM
timeltel
timeltel's Avatar
There's a fluid control valve in the master cylinder. It's purpose is to replenish fluid in the cylinder and lines should fluid bypass the seals. This becomes more a concern as the system wears.
Adjusting pedal engagement at the threaded yoke pushes the piston in the M. C. forward, there is a small range of adjustment available before that port is closed by the valve. At that point, fluid from the reservoir will no longer flow to refresh the lines. Hydraulic pressure falls to the point that the pedal will eventually go to to the floor before actuating the slave cylinder.
Illustration:
http://www.aa1car.com/library/brake_master_cylinder.htm
Old 07-31-2016, 10:25 AM
Sheasta
Sheasta's Avatar
So basically where I left off at the OP I adjusted the pedal higher in the morning due to the clutch being stuck engaged and the after work it lowered again but basically to where I want (right off the floor engagement.). It has bot changed by itself since then. Is it okay for me to leave it like this or can it cause damage ? I feel no resistance shifting gears so clutch is not partially engaged with the clutch down and the clutch doesn't slip at all when in gear so it's fully engaging when off the clutch.
Old 07-31-2016, 02:00 PM
dcains
dcains's Avatar
I asked Ryan (the guy who makes/sells the RJM adjustable pedal) about this once. and my impression is that you run the risk of overextending the slave cylinder, which can cause damage. That's the point of the RJM pedal - you can adjust the pedal height and release point to your preference without damaging the cylinders, which should extend their life.
Old 08-01-2016, 06:20 PM
Sheasta
Sheasta's Avatar
Well I missed out on the final group buy because I dropped $900 on art pipes and resonated xyz pipe so hopefully my clutch height is fine how it is lol. It shifts so much better adjusted this low. How sport cars are supposed to shift.
CUL8ER
Engine Swaps
05-04-2016 10:34 AM
Rev_Night
Drivetrain
04-18-2016 07:53 PM
Quick Reply: HR clutch height adjustment
