Need Daylight runnings lights done for me in Calgary
on
Hi there,newbee here, if anyone can supply me with a source to have these connected up to pass inspection on my US 350 Roadster car, I'd really appreciate the help.
PS. What is the best solution, should a person just have the small park lights utilized instead of the expensive headlights?
Ken
Ken
on
what i did on my friends 2003 350z was use a relay and connect the ignition to parklights and diode isolate so that it cannot feed back. it can all be done in the drivers kick very easily and cleanly.
Vendor - Former Vendor
Go to Princess Auto, get a relay ($7) a cheap fog light kit ($18) and an add a circuit connector ($5).
Pull your washer fluid reservoir fuse, plug your your "add a circuit" socket in and you have a trigger for your fog lights when the ACC (or ignition is on). Then all you ned to do is ground the relay and get it power from the battery. Works great, is safe, and can be removed easly.
Took me about one hour to do it all up, and the fog light come with all the wires.
This is the add a circuit connector:
http://www.cooperbussmann.com/images...86ccd13aad.JPG
