Work Wheels Thread
#1181
I've had a quick search around without any luck. My question is.. How do I navigate around the Work wheel specs chart? Call me a noob but I can't figure out what a lot of the numbers relate to.
I'm wanting to buy a set of 18x10/11 (low offset) Meister M1 3p wheels. I've got the Brembo GT 355mm BBK front and 325mm rear. I guess I'll need R-disk front? Not sure about the rear.
A little help would be great!
https://my350z.com/forum/members/29216-ravspec.html
#1186
From some searching around I believe you would need the T disc all around, contact Mark at Ravspec for confirmation, he is the go-to for any Work related questions:
#1188
hey yall, just a quick question. i am close to ordering my work meister s1. just want to see if i got my order correct. its a 2006, no brembo, base model.
19x9.5 +12 offset r-disc
19x10.5 +10 offset o-disc
is this setup going to work?...i am aware i will be rolling my fenders. just need clarification that i got the disc right.
thanks as always
thanks as always
#1191
on
#1198
on
Okay guys, I have a quick question. I am about to pick up a set of kiwamis 18x9.5/10.5. I want the rear offset to be +15 but for the front should I go with +12 or +20? I will be running a 265/35/18 up front on kwv1 coilovers. I was leaning towards the +12 as it is closer to +15, but I don't want too much poke or have issues with the front fenders. I have searched pictures and comments, lol but the offsets look pretty much the same to me. Thanks in advance!
#1199
Look at these pictures. The owner's setup is 18x9.5 +20 with Michelin Pilot SS 265/35/18 front and 18x10.5 +15 with Michelin Pilot SS 285/35/18 rear. Lowered about 1.5" in the front and about 1.75" in the rear. Hope this helps you make the right choice.
#1200
Senior Super Moderator
