Volk GT-S thread
#1262
350Z/370Z Tech Moderator
GT-S uses a "conventional" lug nut (30-deg taper/acorn style) BUT... not sure if the 21mm head OEM lug nuts will fit well in the narrow confines of the bolt hole "tunnel"; that is, the nut will fit but a traditional socket may be tight. I would suggest aftermarket lugs - Project Kics, Rays, your choice. If you buy Rays, sets will include the smaller, 19mm deep socket required.
I used some inexpensive tapers to affix my Volks (SF-Win) to my car initially and was NOT comfortable with how they worked so swapped for Rays when a set came up for grabs from a fellow forum member.
Another caveat.... if you do opt for the smaller head tuner lugs, make sure you carry the socket, key lock and appropriate removal device in case of flats as the OEM lug wrench will no longer fit.
Cheers,
Mic
#1264
Hmm another question related to gts wheels? My gts wheel center is magnesium blue, which at am not crazy about at all. And I was quote $1000 just to powdercoated the wheel centers?? Just remove the centers and powdercoated them and put them back on the barrels? ?? My question is if the price is about right???
#1265
If you take the wheel faces/centers off yourself (disassemble) and take those to a powdercoater you should be paying ~400-600ish give or take?
#1268
Yah man, found another powdercoater and of if i disassemble them and bring the centers to him will only cost me 200 bucks for sandblast and powdercoated coat them. Much more attractive number I guess
#1269
Ok, got my wheels back and about to assemble the faces back on to the barrels. But I don't know how much torque is needed? Also do I need thread locker, something like loctite on the screws when I tightening them?
Thanks in advance guys
Spoolin'Fool (03-03-2016)
#1273
I actually did marked them. But I don't think it's serious though. 2 faces and 2 barrels for front and rear. Worst case just swap them back
