Aggressive Wheels and Stretched Tires....Welcome
#123
on
Originally Posted by daytona350z
i never said anything about stretching tires in that post. why even bring it up. it was in reference to 335's on a z just in case you missed that, which you obviously did.
#124
on
Originally Posted by jinsei888
The eastwood is what i used, and it is NOT good for slammed car, with tight suspension, as your wheel hub is pulled up tightly up towards the fender--the eastwood arm is too tall for those applications
Make sure you use a heatgun (i used the midpriced Wagner heat gun from OSH) and use LOTS of patience when heating it up, heat it til it is paint-flexible, if it bubbles, just back off, the paint will settle flat again and readhere--don't freak out, it's normal and the paint is fine when it recools. I took about 1 hour per corner of the car. Expect to take that long if you plan to do a clean job; get a friend to help and hold the gun and heat as you slowly move back and forth inch at a time; it helps a lot that way. Yes, you WILL be sweating--it SHOULD get that hot for you to work on it
#125
on
Originally Posted by sry110
Just curious...I've seen different wheels on each side of the car before, but never different wheels front and back. Although I guess LE's don't come in the size he needed to achieve the look he wanted.
lol go to drift event or a drag event.....ppl run diff type wheels on the back all the time.....
lol
#127
on
Originally Posted by ghost
I've had good experiences with the eastwood piece.
#133
about the fender rolling questions....I read up on it here. http://www.rollyourfender.com/ then I rolled mine and a friend's rear fenders. It is very easy. Just timely and it is a lot easier with two people. I rolled while he used the heat gun.
