| New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into My350Z.com, click logo to login |
| Register | 370/350Z Photo Gallery | FAQ | Members List | Calendar | Arcade | Search | Today's Posts | Mark Forums Read | Garage | TSB & Recalls | Used Cars | Vendor Directory |
| Welcome to my350z.com! |
Welcome to my350z.com. You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today! |
Thread Tools | Search this Thread |
#1 |
I have searched but there seems to be difference answers, so i hope someone here can help me out.
So I have Rota Torques and I want to put my TPMS from my stock 08 rims into my Torques. Will the TPMS be compatible with the Torques and will I need to reprogram my TPMS? Some say since these are my original TPMS I wont need to reprogram them but I am not sure. Thank you -James
__________________
08 PPW BASE |
#2 |
MY350Z.COM ![]() |
No reprogramming is necessary. Just move them from old wheels to new.
Reprogramming is only necessary if you get sensors from another car. Yours are already recognized by your cars computer.
__________________
2004.5 Daytona Blue Track Nismo • Volk • Hotchkis • Endless • Centric • Koni • Powergrid • Motordyne • Thermo-tec • Pi-Thon • Infinity • KP Technologies • B-Cool • Classic Soft Trim • Kenwood • Sirius • AudioVox • Valentine {Stealth} • Zaino New to MY350Z? Have a question? Please read this thread first: Top 100 Questions Thread (CLICK) |
#3 |
James - the stock (original) TPMS can be installed with no reprogramming. You will need to have the tires dis-mounted and re-mounted.
__________________
05 Z (dd) / 97 4Runner (z-parts runner / 4 sale soon) / 84 Carrera Targa (wish I didn't sell) / 84 Supra (1 of the 1st tuner cars)
#4 |
Thank you for the quick responses
Does anyone know if they are compatible with the rota torques?
__________________
08 PPW BASE |
#5 |
MY350Z.COM ![]() |
Looking at a picture of the Torques - it looks like they might mount the same as they do on the OEM wheels. As long as the valve stem hole goes in at an angle, you're probably good. The sensor/stem is angled so that it can be positioned parallel to the surface of the barrel. You'll see when they dismount the tires from the old wheels how they should be positioned.
If the valve stem hole is 90º to the barrel of the wheel, then they don't usually fit because the sensor will stick up too much.
__________________
#6 |
2007 Nissan 350Z |
Rota wheels are setup to accomodate 350z OEM TPMS sensors. you should have no problems. (i have rota grids)
__________________
Latest Vid: http://www.vimeo.com/6772953 More Videos at: http://www.vimeo.com/edgarsanchez |
#7 |
i just got rota wheels with tpms from a g35 and no lights came on, i guess those even work without reprograming.
#8 |
thanks a lot guys!
__________________
08 PPW BASE |
#9 |
I've got Rota SVN's and had no problem swapping from the stock rim to the SVN. Just remember to install each TPMS sensor back in its original position, i.e., sensor from front left stock rim should go on the NEW front left, sensor from stock rear right goes to NEW rear right, .............
#10 | |
Old fart
Quote:
Dave
__________________
|2006 Silver Grand Touring|Motordyne 5/16" Spacer|MREV2|Motordyne Single Shockwave))) & VQ Exhaust |v.1 Track wheels|Coastal Metals Cooling Plate|NRG Hood Dampers|
#11 |
MY350Z.COM ![]() |
Yes, for 2007+ cars you don't have to worry about which sensor goes where. There is no readout anymore so position no longer matters.
__________________
#12 |
MY350Z.COM Platinum Sponsor
Plug n play unless replacing them with new sensors
__________________
______________________ Neal, Sales Representative 1-877-522-8473 ext 624 www.tirerack.com |
| Tags |
| 350z, blue, compatible, oem, pressure, reprogram, rota, sensor, swap, swapping, tire, torques, tpms, valve, wheel, wheels |
