Im running 19x10.5 +12 te37 all round.
I have a 5mm spacer upfront and a 20mm spacer in the rear
255/35 F
265/30 R
http://www.flickr.com/photos/23932662@N08/5843924117/http://www.flickr.com/photos/23932662@N08/5843924117/ by http://www.flickr.com/people/23932662@N08/, on Flickr
Came across some varrstoen rims on craigslist brandnew for 900, but the only problem is that they are 10.5 all around. i know they will fit in the back but what about the front? please let me know if they can fit the front and if so how can i make them fit
Thread merged with already previous thread on the topic.
An advanced search by title for "square setup" or "10.5" would have yielded you a ton of threads.
how much camber would i need to fit the front and back to make it look flush?with the fenders?
With the +22 yoour looking at? You also want to be able to rotate tires ? Run a 275/30-19 front and rear , a 10mm spacer on the rear , then you should be able to get away with -2 rear camber and around -2 front camber.
If you don't care about rotating tires (honestly there is no need) run the 275/30 front and 275/35 rear with the same amount of camber i mentioned above.
well i was going to lower my car lower then i have it right now cuz its on springs. and i wantd to go with the stretched look
