Square Wheel & Tire Setup Questions
Old 07-09-2012, 04:56 PM
  #141
terrasmak's Avatar
Received 2,283 Likes on 1,645 Posts
Originally Posted by zswickliffe
I heard that 10" didn't fit up front (without modification)
You heard wrong , 18x10 +25 will easily fit , the are people running 18x10.5 +15 up front too. That is my next front wheel size with a 285/35-18 on it.
Old 08-22-2012, 09:14 AM
  #142
zswickliffe
zswickliffe's Avatar
Alright, I think I've decided on 18x9.75 e20. Now I'm trying to decide if I should run 275/35R18 front and 275/40R18 rear. I want an aggressive look but I do live in florida and I'm worried 275 will be worse in rain. Otherwise, they should clear everything and be just fine, right?
Old 09-06-2012, 12:41 PM
  #143
Z-Sam
Z-Sam's Avatar
Default 19x9.5" Sq with ET 20
Guys request a recommended semi aggresive tyre set up for a Sq. set up of 19x9.5", ET20. (These are the only offsets i can get locally)
The car is loweed by approx 1.2" front & 1" rear.
Want the rears tyres to be wider for a staggered look. Dont mind adding spacers as well. Want to avoid the streched tyre look. Fenders are stock.
This is a Daily drive.
Cheers
Old 09-06-2012, 05:47 PM
  #144
terrasmak's Avatar
Well for the thread you posted in
245/35-19 front and 245/40-19 rear if you want the narrow slight stretch
275/30-19 front and 275/35-19 rear if you want wider tires
255/35 or 275/30 all around may also be a good combo for you.
Old 09-06-2012, 09:38 PM
  #145
Z-Sam
Z-Sam's Avatar
Thanks...!
Any pics of these setup?
Old 09-07-2012, 07:38 AM
  #146
Deteria
Deteria's Avatar
Am I doing it wrong?
Old 09-07-2012, 12:27 PM
  #147
terrasmak's Avatar
Originally Posted by Z-Sam
Thanks...!
From the side it will look like any other 19 inch wheel combo running with the proper tire height black tires installed.
Old 09-09-2012, 08:30 PM
  #148
Z-Sam
Z-Sam's Avatar
Default Anyone running 19x9.5" Et 20 sq. setup?
Is anyone running a 19x9.5" Squared setup with ET20?
These are the only set i can get in ROTA IK-R (Grid 2) locally.
Dont want a streatched tyre Euro look. A PHAT tyre look will be prefereed.
Car is lowered by approx 1.5 & 1" (F&R) Stock fenders.
Dont mind using spacers to get the staggered look. Dont want to sacrifice too much of the steering wheel feel by putting very fat tyres upfront either.
Any pics of a similar setup & prefereed tyre sizez wil lbe appreciated.
Cheers
Old 09-09-2012, 08:41 PM
  #149
mr. sparco
mr. sparco's Avatar
Hmm, must've been moved here from a single thread/
Old 09-09-2012, 08:51 PM
  #150
ZS14RR
ZS14RR's Avatar
You're in Dubai? I think you can do better than that.
Old 09-09-2012, 08:57 PM
  #151
Z-Sam
Z-Sam's Avatar
Haha I have heard that before. I would like to get a set of original TE37 but are very expensive after adding shipping. Plus just got the car so have a budget.
These are available locally in stock. I dont track. This is a weekend car.
Any pics of this setup ??
Old 09-09-2012, 09:49 PM
  #152
terrasmak's Avatar
The standard 255/35 and 275/35 will be fine for you.
Old 09-10-2012, 11:58 AM
  #153
Z-Sam
Z-Sam's Avatar
Thanks ...Any pics of this setup?
Old 09-10-2012, 12:06 PM
  #154
terrasmak's Avatar
On your car it will look like a bronze wheel with a black rubber tire mounted on it, it will also have the same tire height as a stock Z , just with a bigger wheel.
Old 09-10-2012, 12:50 PM
  #155
Z-Sam
Z-Sam's Avatar
Thanks .....but i wanted to see the tyre profile & how it sits with the fenders etc. Hence a pic request.
Trying tosearch all the posts. But majority run staggered with 10.5" rear.
Old 09-10-2012, 01:06 PM
  #156
terrasmak's Avatar
Look for sommeone running an 8.5 and 9.5 +20 combo , that will show you how the rear looks, then look at someone running a 9.5 and 10.5 combo, that will show you what the front looks like. I bet there is a Rota wheel thread too. Look there.
Old 09-11-2012, 11:22 AM
  #157
Z-Sam
Z-Sam's Avatar
Cant get 255-35-19 locally.
Will 245-35-19 front & rear 275-35-19 on square 19x9.5 ,ET20 all around- work well?
Both front & rear 35 profile will not give me a rake?
Old 09-11-2012, 11:48 AM
  #158
terrasmak's Avatar
That will also work well, and yes you will have the proper rake in cause by tire height.
Old 09-11-2012, 12:10 PM
  #159
Z-Sam
Z-Sam's Avatar
My question meant. I dont want a rake.I want the car sitting level.
Old 09-11-2012, 01:52 PM
  #160
terrasmak's Avatar
Well the wheel wells are different from front to rear, when you run the same height tire and lower it for equal gap, the rear looks lower than the front. If you want it level, keep the stagger in tire height and lower it so your fender gaps are the same.
Quick Reply: Square Wheel & Tire Setup Questions
