Volk TE37 Thread
#63
Sorry, i'm kinda new with the wheel sizes and stuff. so, a good look would be 18x9.5 in the front and 18x10.5 in the rear, and a +22 offset in the front and rear? J/w
#66
on
[IMG]<a href="http://www.flickr.com/photos/46221628@N05/4891824250/" title="copy6 by koukiz33, on Flickr"><img src="http://farm5.static.flickr.com/4093/4891824250_c36efdbab5_b.jpg" width="1024" height="683" alt="copy6" /></a>[/IMG]
mercury silver. +12rear +12front with 3mm spacer. so +9
#68
on
<a href="http://www.flickr.com/photos/46221628@N05/4891251797/" title="910314279_fairladies-25 by koukiz33, on Flickr"><img src="http://farm5.static.flickr.com/4140/4891251797_b18a88149b_b.jpg" width="1024" height="681" alt="910314279_fairladies-25" /></a>
one more of the wheels
#71
on
Here's a quick shot of mine at a local show last week... I sold my Stance GR+ to buy the wheels, so excuse the wheel cap and also I have the Veilside V1 sides and Top secret rear underfin sitting in my basement waiting to be installed... So enjoy my work in progress !!!
#77
on
For the TE37, here are some general guidelines for sizes in our offsets:
- 18" will have more concavity, and no cast in lettering. Very small lip. To me, it's a great look!
- 19" will have flatter faces with cast in lettering.
- The rears in 10.5 with a +22 or a +12 will have a nice fat lip.
- +22 will be easiest to fit wider tires, if you plan on dropping much a simple fender roll will get you the clearance you need. I ran 285 on a +22 rear with a 2" plus drop with nothing more than a fender roll
- +12 will be more "flush" to the body and will require more work to fit a wider tire. If you want the "hellaflush" look go +12 with a 255 tire.
- The fronts in 9.5 have a big difference in look for a +22 vs a +12
- +22 will have a small lip, but plenty of room for a fat tire. 255 front tire or larger is generally fine.
- +12 will have fat lip that matches the rear lip, however there are clearance issues and you will be running a 245 or 255 max front tire, with the possible need for adjustable camber front a-arms if you are lowering. Also, if you have the stock Brembo brakes and want to run the +12 fronts, you will need a 3mm spacer for brake clearance. If you are going for "hellaflush", you will want this offset with maybe a 225 - very "aggressive" look and spacers will push it out more.
- Another option for the front is to run a 10.5 +22 up there... you will have the same fitment issues as a 9.5 +12 and I think need the 3mm spacer for Brembo. In essence, a 10.5 +22 is a 9.5 +12 with the extra inch in width added to the inboard of the rim, if that makes any sense.
