Varrstoen Wheels Thread
#142
on
Here's what it looks like with corrested camber and the wheels/tires/offests i mentioned above.
edit- front looks like a weak offset, idk why.... bad pic i guess
#144
on
If I was going with everything I've mentioned in the above post, would the Ichiba Upper Control Arms and Rear Camber/Toe Kit allow me to keep my camber in spec and give it that even drop that you have???
#145
on
yes, it will look like my rear except you;ll have a 285 and i have a 295. and your front will look much better than mine because there will be no gap in between your tire and fender like you can clearly see that mine has. if yo look at my front fender/wheel, just know that that is why you want to correct your camber, because my tires is wearing on about 3 inches on the inside of the tire, and that tire should be much more flush with the lip.
#147
on
#149
on
I have been looking for something other than the plain center caps that these wheels come with. I DONT want to use Volk caps, as Im not trying to pass them off as Volks. I found these:
http://www.courtesyparts.com/logo-ch...tml?cPath=714&
and I was wondering if they would fit. If anyone else has come up with any other ideas, speak up
#159
on
