Tire Pressure Sensors - 2003-2004 Z
Old 10-10-2012, 02:48 PM
phased1
phased1's Avatar
Default Tire Pressure Sensors - 2003-2004 Z
Hello I have a 04 350z and the tires look like they need some air. Is there a wheel air pressure light on the dash? Or do I just got to look at the tires and judge myself?
Old 10-10-2012, 02:54 PM
Waiz
Waiz's Avatar
Read this thread from the TOP 100 FAQ:
https://my350z.com/forum/3788619-post35.html
If you have a 2003-04 Performance, Track, and Touring (MT) you have TPMS installed and may read the Multi-function display on your dash for a readout
If not, you will need to buy a quality tire pressure guage like this one and do it yourself:
http://www.amazon.com/Slime-20096-Pressure-Dial-Gauge/dp/B0020SYY3O/ref=sr_1_1?s=automotive&ie=UTF8&qid=1349909665&sr=1-1&keywords=slime
Old 10-10-2012, 03:13 PM
AdvanZ33
Senior Super Moderator
AdvanZ33's Avatar
You can do it the old fashioned way:
Old 10-10-2012, 03:14 PM
AdvanZ33
AdvanZ33's Avatar
And Waizzz, what is this about 03-04s not having TPMS?
Old 10-10-2012, 03:24 PM
Waiz
Waiz's Avatar
Those are horribly unreliable. I had 3 of them at one point and they all gave me different readings at the same time
My post was not very clear, I meant to state that we don't have the actual pressure reading like the 2005+ do, only the (!) notification.
Old 10-10-2012, 03:27 PM
AdvanZ33
AdvanZ33's Avatar
I have actual pressure readings in my '03
Maybe I'm confused...that happens a lot. Does the 05+ have a different system?
Old 10-10-2012, 03:43 PM
Waiz
Waiz's Avatar
2003-04 Performance, Track, and Touring (MT) models have it
2003-04 Base and Touring (AT) do not
Old 10-10-2012, 03:45 PM
GLRacing
GLRacing's Avatar
And enthusiast
Old 10-10-2012, 06:51 PM
phased1
phased1's Avatar
My car is MT and came with Nismo exhaust and air intake is that considered in the performance category?
Can I turn the acc on and check if I have air pressure symbol?
Old 10-10-2012, 07:06 PM
GLRacing
GLRacing's Avatar
Do you have vdc controls? and cruise controls?
Old 10-11-2012, 03:16 AM
AllstarE4
Sleeps in 350Z
AllstarE4's Avatar
Those parts are optional and don't designate the trim level of the Z.
If you have a low pressure warning it will show in your main gague cluster like this:
If you can actually read your pressures individually they will show on the left of the three gauges above the center waterfall here:
Old 10-11-2012, 05:56 PM
phased1
phased1's Avatar
Thanks so much very helpful! I just filled my tires up anyways and it seems good.
Old 01-17-2015, 03:50 PM
bemsz
bemsz's Avatar
In your picture, I assume the bottom readout is for the driver's side rear tire. Is it even possible that my display is reading the wrong tire? When I adjust the air pressure, in the front, the rear readout changes.
Old 01-17-2015, 07:08 PM
terrasmak's Avatar
Received 2,283 Likes on 1,645 Posts
Unlike some vehicles, the sensors on the Z or set to position. Once set it will always show up on the display in the same spot, no matter where it has been swapped to by a careless installer.
My Jeep, when I rotate tires the sensor assumes it's new position in the display. Even if i install the spare.
lapham3
10-07-2022 03:15 PM
apex locator
07-23-2021 02:27 AM
Quick Reply: Tire Pressure Sensors - 2003-2004 Z
