Cracked Forgestar F14..BEWARE!
I just got mine new about 1 year ago and I have cracks on the INNER LIPS on BOTH rear wheels! One has FOUR cracks (and leaks air) and the other has one minor crack. I found out because one of the wheels had a very slow leak..the other one had no leak, but crack was found on inspection. These are simply defective wheels. I have never raced the car or hit anything in the time I have had these. These are JUNK FOLKS! I didn't takes picks, since I still have them on the car, but if you look around the internet, you'll find many stories about these defective wheels. Here's some picks on THREE DIFFERENT cars with F14s with the EXACT SAME crack that I have. My advice>>>stay AWAY from Forgestar wheels! Mine were F14s, but I assume other styles could have the same problem. Here is a TYPICAL complaint..found on Mercedes forum:
http://mbworld.org/forums/5042553-post4.html
"....19" Forgestar F14's. I noticed I was loosing air in the tire the last 3 weeks and I thought for sure I had a nail in the tire, looked for a nail everywhere but could not find it, finally took the wheel off and found 3 cracks evenly spaced apart on the inside edge of the wheel. Don't ask me how or where I managed to do that because I have no clue."
CRACKS ON THREE DIFFERENT CARS WITH F14 ON THE INNER LIPS>>>
on
They are still a cast wheel when it boils down, you can also see cases of cracked wheels with just about any other company out there. Out of the thousands of sets sold I only found a handful of cracked ones from a quick search, but at the same time I also read about alot of track guys using them to no ill-effect.
Mine are a couple of years old but no cracks so far (knock on wood lol), about to detail the car so I will inspect again soon. I also don't have the F14 model either though.
"Yeah, they only look nice. My rears are defective and cracked all to hell in less than a year. The rims aren't bent at all, so apparently the metallurgy is so bad that they can spontaneously develop cracks on the inside lip without taking any real impact damage. Other rims I've seen hit potholes will bend the crap out of the lip and not crack. These just crack from normal use.
The wheeldude guy isn't responding to my inquiries as to getting new rear wheels at cost to fix the problem, so screw that."
LOL..I've only had these 1 year and never hit a thing! I live in So Cal and drive primarliy in the FWY. Keep in mind, BOTH rears have these cracks..what are the odds? I'ts pretty evident these wheels have more than their fare share of cracks>>>ALL ON THE INNER LIPS!
So, in a YEAR of these wheels, in Burbank.. I am from Ventura, you have never hit a pothole? Also, 3 wheels out of how many sold? I bet you searched the whole web to find the other two pictures.. Also, CA freeways have MANY underpasses that run underneath them, thus creating ridiculous bumps. ... .. Not fooling anyone
BTW..another *story*>>>
"The good: I was very fortunate to have been one of the first recipients of the Forgestar F14 wheel group buy. As written in my positive review, I praised them for relatively quick delivery of product, and what seemed to be a quality wheel.
The bad: Well, two and a half months and 1,200 miles later, the rear driver's side wheel developed a hairline crack. You can see it in the pictures at the bottom.
There was no trauma to the wheel, no potholes, and good roads in my part of Maryland. The wheel could be sold as brand new - that is how pristine and clean it is. The wheel is round, and has no scars or abrasions that would indicate misuse. But, it leaks air through this crack that has been verified with soapy water and a wheel shop. They stated that it is likely that I could claim the wheel was defective, although it can be difficult, because the wheel shows no signs of damage anywhere, is round, but cracked.
So I called **********s and Forgestar to seek an answer. They initially stated that they could not help because the wheel was damaged through my use. I continued to assert that the wheel was not damaged through my negligence, and that I took it to a shop, and would have it inspected by other shops if necessary, to prove that the wheel was not damaged through the normal signs of misuse such as an out-of-round wheel or with visible damage. Plus, even under normal use, in just over two months and 1,200 miles??? I am now stuck without the use of my car, and had to purchase a new set of wheels because I need to get around, and I am genuinely skeptical about the strength of the wheels."
Senior Super Moderator
Did you get a warranty card?
"Forgestar Performance Wheels are backed by a lifetime structural warranty to the original retail purchaser. A limited one year manufacturer's warranty guarantees wheels will be free from defects in materials and workmanship under normal and reasonable use."
Didn't Go Cheap
Sorry for your troubles. I'm not a fan of Forgestar wheels as they give a false impression with their name. At least it's just a crack vs failing into pieces like other brands. If you'd like a set of truly forged wheels and not form flow cast I have a great vendor that will make sure you get a quality wheel. He even sell Forgestar. LOL
Why don't you drive to their office and complain to see if they will offer to fix or at least help you out in some sort of way? They are located in Socal, Anaheim area. Here's the address:
Forgestar Wheels USA
1161 N. Knollwood Cir.
Anaheim, CA 92801
On their website, they advertise the wheels on many high end cars like Lambo, Ferrari & Bentley. That seem to be misleading to regular customers I think.
Anaheim, CA 92801
Like I said...I drive well known..well paived streets and mainly FWY. The tires have very adequate side walls to PROTECT the rims with 275/40. There is no evidence of a ding/bend in the area of the cracks. I've NEVER had a cracked wheel like these...TWO cracked wheels to boot. These ARE NOT from hitting potholes.
