PSA: When asking "will this rub"....
Old 08-17-2014, 02:29 PM
ebaker00
ebaker00's Avatar
Will this rub on stock suspension?
18x9.5 +30
255 40 18 Front
275 40 18 Rear
Old 08-17-2014, 02:35 PM
RUNWDVL
RUNWDVL's Avatar
18x9.5 +30
255 40 18 Front
275 40 18 Rear
Nope
Old 08-17-2014, 02:38 PM
ebaker00
ebaker00's Avatar
Originally Posted by RUNWDVL
Nope
Thanks!
Old 08-25-2014, 04:20 PM
375rngrZ
375rngrZ's Avatar
Default will this rub
pretty sure it wont none the less I don't need any surprises during install.
19x10.5 +30ish with 275/45/19 on the rear obviously might be 275/35/19 im deployed so I cant remember exactly off the top of my head.
Old 08-25-2014, 05:32 PM
RUNWDVL
RUNWDVL's Avatar
Why 45's? Are you off-roading or rock crawling?
Old 08-25-2014, 05:39 PM
375rngrZ
375rngrZ's Avatar
I bought them used that's what came on I really want to say its a 45 stretched but like I said I could be wrong it could be a 35.
Old 08-25-2014, 05:48 PM
RUNWDVL
RUNWDVL's Avatar
35 would fit...45 probably fit if at stock height. Don't quote me on that.
Old 08-25-2014, 05:52 PM
375rngrZ
375rngrZ's Avatar
yeah its at stock so hopefully your right or im gonna be losing my **** when I get back lol thanks for the help.
Old 09-02-2014, 09:34 AM
Smokey9012
Smokey9012's Avatar
Got new wheels put on my 06 z I'm running 18x9.5 +22 all around need help on a good tire size that won't rub currently have tein s techs installed and that's it the tires I have on the wheels now are 255/35r18 I know they are "civic sized" but they will actually fit my subaru just need to get proper fitting tires for the z
Old 09-02-2014, 09:43 AM
travlee
Master
travlee's Avatar
Received 9,046 Likes on 6,512 Posts
255/40 front 275/40 rear.
Old 09-02-2014, 10:49 AM
Smokey9012
Smokey9012's Avatar
Thank you very much
Old 11-05-2014, 11:03 AM
DaveJackson
Master
DaveJackson's Avatar
Will it Rub?
Stock height, stock springs on a 2003 350Z. Fenders not rolled.
Front: 20x9.5 and +20mm with 265/30/20
Rear: 20x12 and +26mm with 325/25/20
Thanks!
Old 11-07-2014, 06:10 PM
terrasmak's Avatar
Received 2,283 Likes on 1,645 Posts
Originally Posted by DaveJackson
Will it Rub?
Thanks!
That's going to be really close with a roll.
Old 12-14-2014, 09:54 AM
818dbz
818dbz's Avatar
Will this rub?
stock suspension
19x9.5f +22 19x10.5r +22
245/35/19 ....275/35/19
Will it look sunken?
Old 12-14-2014, 06:42 PM
terrasmak's Avatar
Originally Posted by 818dbz
Will this rub?
stock suspension
Front will be fine , the rear may need a slight roll depending on how camber is set.
Old 12-16-2014, 12:31 PM
tod1429
tod1429's Avatar
Looking to buy Rota Torque 18x9.5 +20 for all 4 corners. Everything is original now, stock 350z Touring 18x8 +30's. I read a lot about the Rota's fitting, but calculators show the Rota's sticking out 29mm more than stock rims. Visually, this just looks like a rubbing issue waiting to happen. Appreciate any feedback.
New Setup
-Tire size (Front 255/40/18, Rear 275/40/18)
-18x9.5 +20 (Front and Rear)
-Camber spec (? - Not sure, most likely standard alignment)
-Stock height, not lowered
Thanks
Old 12-16-2014, 12:42 PM
travlee
Master
travlee's Avatar
you will be fine, i ran those sizes in the rear being lowered an inch and didnt rub
Old 12-16-2014, 01:05 PM
  #38
tod1429
tod1429's Avatar
Ok. Thanks. This must be an optical illusion. The stock rim/tire edge is almost at the fender.
Old 12-22-2014, 11:15 AM
  #39
Phenom
Toasty
Phenom's Avatar
Received 1,382 Likes on 990 Posts
When your suspension compresses, the wheels will camber in, giving the tire enough clearance to avoid the fender.
Old 12-30-2014, 03:43 PM
  #40
ripley987
ripley987's Avatar
Question Will this rub?
Ok so sort-of a multi part question as I figure out what to do here. Goal is performance and looks (mostly performance).
I'm probably looking to lower my car on RS-R shocks in the Spring, but I need new tires soon and I'm looking at either a 285/35/19 or 275/35/19 rear and 265/40/18 front on Nismo rims
So basically:
-Car lowered on RS-R springs, .6" front and rear
-285/35/19 tires in back, 265/40/19 in front
-19x10" +30 rear, 18x9" +30 front wheels
-Camber spec (don't know, but as close to standard as possible I guess)
Will it rub at all (in any situation) AND will VDC be fine with either a 285 or 275/35/19 rear and 265/40/18 front or will one of the above sizes not work?
Thanks!
Thanks!
Quick Reply: PSA: When asking "will this rub"....
