18" Wheel & Tire Discussion Thread
#1822
Those two fronts are fully interchangeable when running a 275/40 rear. I would say 255 is preferred, but it's not always available.
#1823
will they fit?
Ive got a stock height 05 350z and id like to put some Miro type 398s on. 18x8.5 front with 245/40/18 tires and 18x10.5 with 275/35/18 tire on the back. Wheelfire says the combo will fit but do u guys think they will fit?
#1824
Master
why are you going to have a 2 inch difference in the wheel width? i run 9.5 setup on all corners, the most important thing we need to help is the offset of the wheels. here is a good read for ya
https://my350z.com/forum/10179227-post1.html
#1826
1. You never posted offset
2. Never go to wheelfire again
3. The rear tire you want is 275/40-18
4. Do some research.
#1828
…with 255/40 front and 275/40 rear. I may go with 8.5 x 18” on the front. Not sure yet.
I don’t need the extra expense of a light weight racing wheel.
I have a Redline 350Z. I like the polished rim with either black or gunmetal spokes with the Redline.
#1830
Will these work?
Ok I would like some gt4 wheels here is the link:
http://m.americanmuscle.com/blackgt4-18in-9904-sumitomo-stag.html
They're 18x9 and 18x10 offset is +25. Will the fit or should I go with +40 offset?
#1831
25 is fine, you do not want +40
#1834
Im actually paying around 500 for the wheels. I get a discount at final price on wheels+tired mounted snd ballance shipped to my house is 1,160. Do you still think theyre too much? Just want a cheap set of gloss black for everyday driving.
#1837
Thanks for the advice. I might have to pick up some spacers.
#1838
okay guys i bought them, i test fit them one on with the 235 and it looked like i still had a good amount of room to work with, i drove around a tad bit with one on and it didn't rub at all.. so im hoping a 265 will be fine.
I ordered continentals 265/35 up front
285/35 for the rears...
Will get back to you when my tires come in and i get them mounted!
#1839
That tire combo should work well.
