PSI changes on cold mornings
Just checked the pressure again the passenger side was around 32-33 cold however the drivers side was at 27, so I think I found which tire is the culprit, now to just find out what's causing it, hopefully I can figure it out tomorrow evening once the gf gets home from work. I'm gonna put the electric pump in the car for her just in case
Just hit a tire shop, tell them you have a slow leak, pay $10 , max $20 and they will find it and fix it
But if its common for them to go out after awhile its very possible that's the problem, I doubt the tpms have ever been changed before. And I just hit 100k the other day.
Gonna have to hustle some jits or something...
I'll have to find some turbo Honda's round here to bet on a race, since they act like their ricers can't be beat LOL
Id honestly probably ruin my valve stems trying to do that, I don't know much about tires except how to patch plug and change one lol. I wouldn't know where to start or where to stop. And are you talking about the core or the actual stem you screw the cap onto?
Just wanted to post an update
There was a small screw in the tire causing the leak, I had it patched and the idiot scratched my wheel up and not just the outside edge where I could understand but on the spoke right before where it turns in towards the center which is completely unexplainable and he said it was normal, yeahh right, and the idiot didn't tighten the wheel correctly, he didn't put it all the way against rotor/spacer, just the top part and hand tightened it then just put the lug nuts on the thread and impacted then down in a circle not in the star pattern like your supposed to, which ended up causing tire wobble at speeds over 50 that was intermittent. Was quite angry that I had to take the tire off and put it back on correctly because the shop couldn't do it right.... Anyways found that my tires are getting pretty bald the inside has about 20-25% thread left so gotta start looking for new tires. These lasted almost 20k miles so far though!
Man i dont know if you have a Discount tire company out there but worth finding out.. i work for an America's tire co in cali (same company but different name in cali) we do free flat repairs, that even includes a free tpms rebuild kit swap in that process once tire is repaired. And we definitely do not scratch our customer's wheels. you should also consider us in your search for tires. we beat any advertised price and have the best warranties. we dont work off commission like other shops so you truly get a honest opinion and price. just trying to help a fellow member get a good price and service. good luck.
11-09-2020 10:27 AM
04-04-2016 07:52 AM
